Calcite-dialog closes when closing other floating elements inside (2.11.1)
1714
08-20-2024 11:13 PM
FC_Basson
With the new calcite-dialog component, when closing other "closable" elements contained within the dialog, the dialog also closes.  The happens with panels (inside a shell panel) and other dialogs.
Also, placing a calcite-shell component within the dialog, you need to resize it manually so that it does not cover the dialog header and footer components.
Here is a Codepen to demo the issues: https://codepen.io/fcbasson/pen/YzoazZE
This did not happen before the 2.11.x release.
It seems that the close button for all closable elements is a calcite-action component with a data-test="close" attribute, which is also now true for the calcite-dialog component, but it was not for the deprecated calcite-modal component.  So if you click the close button with the data-test="close" attribute inside a dialog, the event bubbles up and also closes the dialog.
Are there any other components to achieve the desired functionality?
MattDriscoll
MattDriscoll
Hi @FC_Basson thanks for reporting these issues!
I'll create an issue for this one.
We have an issue for this one already. https://github.com/Esri/calcite-design-system/issues/10095
No, but you can continue using the modal component until these bugs are fixed.
FC_Basson
Thanks Matt.
MattDriscoll
