calcite components alignment
2141
08-26-2022 10:19 AM
LefterisKoumis
I am get trying to get the calcite components line up next to each other but it seems that css is overwritten by the table? Here is an example.
https://codepen.io/lkoumis1/pen/wvmbbYR
LefterisKoumis
I figured it out. The solution was to get the components' div out of the tableDiv, and adjust the height in css.
<div id="appContainer">
        <div id="viewDiv"></div>
        <div id="tableContainer" class="container">
          <div id="select-by-rectangle" style="float:left; text-align:center;">
            <calcite-button appearance="transparent" color="red" icon-start="selection-x" scale="s">Select by
              rectangle
            </calcite-button>
          </div>
          <div id="clear-selection" style="float:left; text-align:center;">
            <calcite-button appearance="transparent" color="red" icon-start="erase" scale="s">Clear
              Selection
            </calcite-button>
          </div>
          <div id="ExportInfo" style="float:left; text-align:center">
            <calcite-button appearance="transparent" color="red" icon-start="download-to" scale="s">Export
              to CSV
            </calcite-button>
          </div>
        </div>
        <div id="tableDiv"></div>
      </div>
KittyHurley
Hi @LefterisKoumis, In this case since the actions are related to the FeatureTable widget, you could leverage the widget's properties to add the functionality to the menu using the "menuConfig" property.
For instance:
const featureTable = new FeatureTable({
      view: view,
      layer: featureLayer,
      // Custom FeatureTable menu items
      menuConfig: {
        items: [
            label: "Clear Selection",
            iconClass: "esri-icon-erase",
            clickFunction: function (event) {
              // Clear selection functionality
            label: "Export to CSV",
            iconClass: "esri-icon-download",
              // Export to CSV functionality
      tableTemplate: {
        columnTemplates: [
            type: "field",
            fieldName: "state_name",
            label: "State",
            direction: "asc"
            type: "field",
            fieldName: "PercentagePrivate",
            label: "Private school percentage"
            type: "field",
            fieldName: "PercentagePublic",
            label: "Public school percentage"
      container: tableDiv
Here's a Codepen for the full context.
LefterisKoumis
Thank you. I had the components previously setup in the menuConfig, the same way as you mentioned.  It is a good solution for a small number of tools. However, since I need to have a longer list of tools to be used for the feature table, it will make a long listing for the user  to find the tool they need. To improve user's experience, I think placing the tools on the top of the feature table for easy and quick access is a better approach. Is there a way to deal with the issue that I described? Thanks.
LefterisKoumis
              rectangle
            </calcite-button>
          </div>
              Selection
            </calcite-button>
          </div>
              to CSV
            </calcite-button>
          </div>
        </div>
      </div>
