Want more Attribute Rules Videos?
3488
8
01-13-2021 01:17 PM
HusseinNasser2
Hey guys,
if you want to stay up to date with all our new attribute rules video make sure to save this YouTube playlist, https://www.youtube.com/playlist?list=PLGZUzt4E4O2I-L8Dh8gIfWUeCcyz9hLLx
We will keep updating it with content frequently.
-Hussein
Share your videos with friends, family, and the world
JoeBorgione
Awesome @HusseinNasser2 !  Thanks for posting
That should just about do it....
YinghongLi1
i re posted to the video creator.  sorry....
YinghongLi1
I followed your video and created an attribute rule but i got schema lock error (000464).  I know for sure that i was the only one using the data.  it is Oracle SDE database.
i even got the same error message when i only populated a feature with a string constant "Test".  so got be something else causing the problem.
thanks and it is a great video.
JoeBorgione
I suggest you copy your data to a file geodatabase and do your development there.
YinghongLi1
but at end i still have to move the things back to enterprise database.  do you have any suggestion on how to work with SDE database?
thanks
JoeBorgione
You said you are sure that no one else is on the db and yet you get a schema lock.  Okay, then something else must be wrong.  All I'm saying is it's easier to learn how to craft attribute rules without the overhead of an enterprise gdb getting in your way.  Your call...
YinghongLi1
ok.  thanks......
Brian_Wilson
Honored Contributor
Can you tell me what "frequently" means in this case? 😂
Thanks for the Dev Summit ones from 2023 and 2024, those were good.
