Change VALIDATIONSTATUS column value in calculation rule
993
06-17-2024 11:13 AM
mohanprajapati
I want to modify the validationstatus column to 0 when the Python program inserts/updates/deletes the record.  I tried to modify the validationstatus column' value using the result and edit parameters of calculation attribute rules. However, validationstatus column is not editable using this way.
My main objective is to set validationstatus  column's value to 0 when the record is inserted using Python program.
Could you please share other options to do it?
OrrGvili
why not set defult  value to zero ?
can you post the  attribute rule code ?
