I Cannot activate "Add Error Layers"
2143
01-20-2022 04:06 AM
Hala_Ghareeb
I Cannot activate "Add Error Layers" for a layer to do inspect errors of the validation rules.
Tags (1)
HusseinNasser2
Which Pro version?
Does the class have batch calculation or validation rules (check the datasource to see if GDB_Validationxxxx classes exist)
Which data source is this ? (filegdb/mobilegdb/enterprise feature service?)
Note that the add error layers only work through mobilegdb/filegdb and in feature services after consuming the feature service which has a validation capability enabled.
this video might help https://www.youtube.com/watch?v=HFHJFCn2E1M
Learn about batch calculation rules. We discuss how they work as well as the benefits and differences between these and classic calculation and constraint rules. If you are interested in following along, you can find a sample geodatabase with scripts at the following location: ...
GentilcoreDena
I am currently working in ArcGIS Pro version 2.9 and am experiencing the same issue. I watched the attached video in hopes of being able to correct the issue of not having the option to click the 'add errors layer' but the steps that were shown did not assist me. Is there another process of enabling this option?
