Scripting - Is GPS being Used.
2689
03-19-2013 12:46 PM
TimothyPower
Just because Application.GPS.IsOpen returns true, doesn't mean GPS is being used to plot points, It just means GPS is On. I need to know when the user clicks ok if the feature being added was created using GPS or Digitize. Can anyone tell me the property I need to access to determine this.
Tags (3)
GarethWalters
Hi Timothy,
The quickest solution I can think of would be to set Averaging on and then check the GPS.OnAverageStart property. You can still have averaging as a single location.
I hope this helps.
Cheers,
Gareth
TimothyPower
If I try this than I guess I can assume if they are Not using GPS to plot their points, OnAverageStart would have a value of zero?, Or Null?, or Nothing?
TimothyPower
If I try this than I guess I can assume if they are NOT using GPS to plot their points, OnAverageStart would have a value of zero?, Or Null?, or Nothing?
TimothyPower
Hi Timothy,
I hope this helps.
Cheers,
Gareth
