Preventing Self-Intersecting Polygons
5418
08-07-2015 10:53 PM
IngridHogle
I've been testing out this code to detect self-intersecting polygons in ArcPad, but I am getting inconsistent results including a LOT of false positives and some false negatives. I cannot figure out the pattern to the problem. This is based on the code here: How to determine if a polygon is self-intersecting using either ArcPad 8.0 or ArcMap 9.3.1? - Geogra...
Is the issue trying to test this in the office, rather than with real GPS-collected data?
Sub CheckSelfIntersectingPolygon(objSH)
      Dim intJ, intI, objPart, objVertex, strVertexNo
           'Initialize intJ
      intJ = 1
          'Display information for each part of the feature
      For Each objPart in objSH.Parts
           'MsgBox "Part " & intJ & " contains " & objPart.Count & " vertices.",vbOKOnly," Vertex Count"
            'Initialize intI
            intI = 1
           'Display information for each vertex in the current part
           For Each objVertex in objPart
                strVertexNo = "vertex(" & intI & ") " & objSH.isPointIn(objVertex)
                'console.print strVertexNo
                if objSH.isPointIn(objVertex) = "True" then
                      msgbox "This is a self intersecting polygon. You will need to recollect it."
                     '& VBCr & strVertexNo
                      exit sub
                end if
               'Increment intI
                intI = intI + 1
      'Increment intJ
           intJ = intJ + 1
End Sub
CraigGreenwald
Ingrid, here is the script I sent you - posted here as requested for others to use:
Option Explicit
Sub TestIt()
     If (Map.SelectionLayer Is Nothing) Then
          Exit Sub
     End If
    Dim pRS
    Set pRS = Map.SelectionLayer.Records
    pRS.Bookmark = Map.SelectionBookmark
    Dim pPoly
    Set pPoly = pRS.Fields.Shape
    msgbox "Self intersects: " & IsSelfIntersectingPoly(pPoly)
End Sub
Call TestIt()
Function IsSelfIntersectingPoly(p_pPolygon)
    '++ if input shape is not a polygon, return false
    If (TypeName(p_pPolygon) <> "ISPolygon") Then
        IsSelfIntersecting = False
        Exit Function
    End If
    '++ build segments
    Dim pLineSeg, pPts, pPt
    Dim arrSegments()
    ReDim arrSegments(p_pPolygon.Parts(1).Count - 2)
    Dim iSegCt
    For iSegCt = 1 To UBound(arrSegments)+1
        Set pLineSeg = Application.CreateAppObject("Line")
        Set pPts = Application.CreateAppObject("Points")
        Set pPt = p_pPolygon.Parts(1)(iSegCt)
        pPts.Add pPt
        Set pPt = p_pPolygon.Parts(1)(iSegCt+1)
        pPts.Add pPt
        pLineSeg.Parts.Add pPts
        Set arrSegments(iSegCt-1) = pLineSeg
    Dim i,j
    For i = 0 To UBound(arrSegments) - 1
        For j = (i+1) To UBound(arrSegments)
            If (DoLineSegmentsCross(arrSegments(i),arrSegments(j))) Then
                IsSelfIntersectingPoly = True
                Exit Function
            End If
    IsSelfIntersectingPoly = False
End Function
'++ Routines below adapted from Peter Kelley's solution posted at:
'++ https://github.com/pgkelley4/line-segments-intersect/blob/master/js/line-segments-intersect.js
Function DoLineSegmentsCross(p_Seg1, p_Seg2)
    Dim pSeg1Pt1, pSeg1Pt2, pSeg2Pt1, pSeg2Pt2
    Set pSeg1Pt1 = p_Seg1.Parts(1)(1)
    Set pSeg1Pt2 = p_Seg1.Parts(1)(2)
    Set pSeg2Pt1 = p_Seg2.Parts(1)(1)
    Set pSeg2Pt2 = p_Seg2.Parts(1)(2)
    '++ intersection at nodes is ok
    If (EqualPoints(pSeg1Pt1, pSeg2Pt1) Or EqualPoints(pSeg1Pt1, pSeg2Pt2) Or EqualPoints(pSeg1Pt2, pSeg2Pt1) Or EqualPoints(pSeg1Pt2, pSeg2Pt2)) Then
            DoLineSegmentsCross = False
            Exit Function
    End If
    Dim r,s
    Set r = SubtractPoints(pSeg1Pt2, pSeg1Pt1)
    Set s = SubtractPoints(pSeg2Pt2, pSeg2Pt1)
    Dim uNumerator,denominator
    uNumerator = CrossProduct(SubtractPoints(pSeg2Pt1, pSeg1Pt1), r)
    denominator = CrossProduct(r, s)
    If (uNumerator = 0 And denominator = 0) Then
        '++ they are colinear
        '++ do they overlap? (are all the point differences in either direction the same sign?)
        Dim bOverlapTest
        bOverlapTest = ((pSeg2Pt1.x - pSeg1Pt1.x < 0) XOr (pSeg2Pt1.x - pSeg1Pt2.x < 0) Xor (pSeg2Pt2.x - pSeg1Pt1.x < 0) Xor (pSeg2Pt2.x - pSeg1Pt2.x < 0)) Or _
            ((pSeg2Pt1.y - pSeg1Pt1.y < 0) XOr (pSeg2Pt1.y - pSeg1Pt2.y < 0) XOr (pSeg2Pt2.y - pSeg1Pt1.y < 0) XOr (pSeg2Pt2.y - pSeg1Pt2.y < 0))
        DoLineSegmentsCross = bOverlapTest
        Exit Function
    End If
    If (denominator = 0) Then
        '++ lines are parallel
        Exit Function
    End If
    Dim u,t
    u = uNumerator / denominator
    t = CrossProduct(SubtractPoints(pSeg2Pt1, pSeg1Pt1), s) / denominator
    DoLineSegmentsCross = ((t >= 0) And (t <= 1) And (u >= 0) And (u <= 1))
End Function
Function CrossProduct(p_P1, p_P2)
    CrossProduct = p_P1.X * p_P2.Y - p_P1.Y * p_P2.X
End Function
Function SubtractPoints(p_P1, p_P2)
    Dim pResultPt
    Set pResultPt = Application.CreateAppObject("Point")
    pResultPt.X = p_P1.X - p_P2.X
    pResultPt.Y = p_P1.Y - p_P2.Y
    Set SubtractPoints = pResultPt
End Function
Function EqualPoints(p_P1, p_P2)
    EqualPoints = (p_P1.X = p_P2.X) And (p_P1.Y = p_P2.Y)
End Function
CraigGreenwald
Option Explicit
Sub TestIt()
          Exit Sub
     End If
    Dim pRS
    Dim pPoly
End Sub
Call TestIt()
        Exit Function
    End If
    '++ build segments
    Dim arrSegments()
    Dim iSegCt
        pPts.Add pPt
        pPts.Add pPt
    Dim i,j
                Exit Function
            End If
End Function
            Exit Function
    End If
    Dim r,s
        Dim bOverlapTest
        Exit Function
    End If
        Exit Function
    End If
    Dim u,t
End Function
End Function
    Dim pResultPt
End Function
End Function
RebeccaStrauch__GISP
Hi Craig,
Thanks for posting.  But can you edit the post and try Posting Code blocks in the new GeoNet
IngridHogle
Thank you. Works like a charm!
