How to find self-intersecting polygons that failed sync checkin
3508
08-18-2015 04:34 PM
IngridHogle
We just discovered that when we sync, the message alerting us to self-intersecting polygons displays in the sync report window on our mobile device, but the polygon is then apparently marked as checked in, so that we cannot identify the presence of an error back in the office unless the field staff informed us of problem so we know that we have to export the polygon from AXF to shapefile. Now that we've identified the problem, we have about 100 AXF files that we will have to open in ArcPad Studio, export the polygons as shapefiles, check for polygons that did not get added to our SDE dataset, and add these manually. Our AXF files are large and take several minutes to open, so this is going to be a time-consuming and tedious task. Is there any workaround or streamlining we could do to speed up this process?
