Save Mxd Document using C# code
4518
04-24-2013 10:55 PM
ChaitanyaPeddinty
Hi My requirement is to Open an Arc map application and close it automatically through C# coding.
For that I Wrote below code
IDocument pDoc = new MxDocumentClass();
                pApp = pDoc.Parent;
                pApp.OpenDocument(sMxdFileName);
                if (pApp != null)
                    pApp.Shutdown();
  // pApp.saveDocument is not working
Everything is fine , But before  shutdown statement is executing , In Map same dialog box like save changes to Mxd and Yes or No Buttons are avaialble there. We should able to handle that control also through coding before execute the Shutdoen statement.i.e we should close the document opened with affected changes.
can u please suggest me the code for that
JasonPike
Maybe you can try something like this:
IDocument pDoc = null;
IApplication pApp = null;
try
    pApp = pDoc.Parent;
    // save file
    IMapDocument mapDoc = (IMapDocument)pDoc;
    mapDoc.Save(true, true);
    // suppress "do you want to save dialog"
    IDocumentDirty2 dirty = (IDocumentDirty2)pDoc;
    dirty.SetClean();
finally
    if (pDoc != null)
        Marshal.ReleaseComObject(pDoc);
    if (pApp != null)
        pApp.Shutdown();
        Marshal.ReleaseComObject(pApp);
