Releasing memory using Marshal.FinalReleaseComObject
10217
23
03-07-2012 11:37 AM
USFS_AGOLAdministrator
Hi all,
I know this is alot of code, but you have to see the whole thing understand the problem. The code below is doing a Reverse Eliminate of sorts by looping through a selected set of sliver polygons, doing a spatial selection to find out what polygons are touching the slivers, getting the 2nd largest polygon that touches the sliver, and merging the sliver to the second largest polygon by unioning them together, and deleting the original sliver polygon.
It works beautifully well, except it bombs out after processing ~900 slivers with a memory error. I've tried everything I can think of to release the memory, as you will see below. Can anyone see anywhere I can release more memory?
Try
     Using comReleaser As ESRI.ArcGIS.ADF.ComReleaser = New ESRI.ArcGIS.ADF.ComReleaser()
Dim pFeat As IFeature = Nothing
Dim pEnumFeat As IEnumFeature = CType(pMap.FeatureSelection, IEnumFeature)
'Dim pEnumFeat As IEnumFeature = CType(pFLayer.SelectionSet, IEnumFeature)
pEnumFeat.Reset()
Dim pFCur As IFeatureCursor = Nothing
Dim pSF As ISpatialFilter
pSF = New SpatialFilter
Dim pTopoOp As ITopologicalOperator
Dim pLargestAdj As IFeature = Nothing
Dim sliverFeat As IFeature = Nothing
sliverFeat = pEnumFeat.Next
Do Until sliverFeat Is Nothing
'this is really the smallest
pLargestAdj = GetLargestAdjacent(sliverFeat, True, pSF, pFCur, pFClass)
If Not pLargestAdj Is Nothing Then
pTopoOp = CType(pLargestAdj.ShapeCopy, ITopologicalOperator)
pLargestAdj.Shape = pTopoOp.Union(sliverFeat.ShapeCopy)
updateFeature(m_pFLayer.FeatureClass, pLargestAdj.OID, pLargestAdj.Shape)
sliverFeat.Delete()
Marshal.FinalReleaseComObject(sliverFeat)
Marshal.FinalReleaseComObject(pTopoOp)
Marshal.FinalReleaseComObject(pLargestAdj)
Else
Debug.Print("nothing adjacent to: " & sliverFeat.OID)
End If
nCurRecNo = nCurRecNo + 1
My.ArcMap.Application.StatusBar.Message(0) = nCurRecNo.ToString & "/" & n.ToString & " records complete."
Application.DoEvents()
comReleaser.ManageLifetime(sliverFeat)
Loop
'Stop editing and save the edits
pEditor.StopEditing(True)
Runtime.InteropServices.Marshal.FinalReleaseComObject(pLargestAdj)
End Using
Catch ex As Exception
MsgBox("Error: " & ex.StackTrace, , "RElimAddinPB_onClick")
End Try
'!!!!!!!!!!!!!!!!!!!!!!!This function is where it bombs out after ~900 records!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Function GetLargestAdjacent(ByVal pFeat As IFeature, ByVal getSecondLargest As Boolean, ByVal pSF As ISpatialFilter, ByVal pFcur As IFeatureCursor, ByVal pFC As IFeatureClass) As IFeature
Try
pSF.Geometry = pFeat.Shape
pSF.SpatialRel = esriSpatialRelEnum.esriSpatialRelIntersects
pFcur = pFC.Search(pSF, False)
If pFC.FeatureCount(pSF) < 3 Then 'This is set if there is only polygons on one side of the sliver
getSecondLargest = False
End If
Dim pFeat2 As IFeature = Nothing, pLargestFeat As IFeature = Nothing
comReleaser.ManageLifetime(pFeat2)
comReleaser.ManageLifetime(pFcur)
Dim dMaxArea As Double = 0
pFeat2 = pFcur.NextFeature
Do Until pFeat2 Is Nothing 'This loop executes everytime, no matter if there are slivers on both sides or not
If Not pFeat2 Is pFeat Then
If pLargestFeat Is Nothing Then
pLargestFeat = pFeat2
dMaxArea = GetArea(CType(pFeat2.Shape, IArea))
Else
If GetArea(CType(pFeat2.Shape, IArea)) > dMaxArea Then
Runtime.InteropServices.Marshal.FinalReleaseComObject(pLargestFeat)
Runtime.InteropServices.Marshal.FinalReleaseComObject(pFeat2)
End If
End If
End If
pFcur.Flush()
Loop
Marshal.ReleaseComObject(pFcur)
'comReleaser.Dispose()
If getSecondLargest Then 'This loop will execute only if there are polygons on both sides of the sliver
'pFCur = pFC.Search(pSF, False)
pFcur = m_pFLayer.FeatureClass.Search(pSF, False)
Dim pSecondLargestFeat As IFeature = Nothing
Dim dSecondMaxArea As Double = 0
If Not pFeat2 Is pLargestFeat Then
If pSecondLargestFeat Is Nothing Then
pSecondLargestFeat = pFeat2
dSecondMaxArea = GetArea(CType(pFeat2.Shape, IArea))
Else
If GetArea(CType(pFeat2.Shape, IArea)) > dSecondMaxArea Then
End If
End If
End If
End If
pFcur.Flush()
Loop
pLargestFeat = pSecondLargestFeat
End If
GetLargestAdjacent = pLargestFeat
End Using
MsgBox(ex.Message, , "Ex routine")
MsgBox(ex.StackTrace, , "Ex routine")
GetLargestAdjacent = Nothing
End Try
End Function
Private Sub updateFeature(ByVal fc As IFeatureClass, ByVal oid As Integer, ByVal newGeom As IGeometry)
Dim queryFilter As IQueryFilter = New QueryFilter() With { _
.WhereClause = Convert.ToString(fc.OIDFieldName) & " = " & oid.ToString() _
Dim featureCursor As IFeatureCursor = fc.Update(queryFilter, False)
Dim featureToUpdate As IFeature = featureCursor.NextFeature()
featureToUpdate.Shape = newGeom
featureCursor.UpdateFeature(featureToUpdate)
Runtime.InteropServices.Marshal.ReleaseComObject(featureToUpdate)
featureCursor.Flush()
End Sub
Function GetArea(ByVal pArea As IArea) As Double
GetArea = pArea.Area
End Function
NeilClemmons
Honored Contributor
Here's part of the documentation:
http://help.arcgis.com/en/sdk/10.0/arcobjects_net/conceptualhelp/index.html#/Releasing_COM_reference...
And here's the documentation for the ManageLifetime method:
http://help.arcgis.com/en/sdk/10.0/arcobjects_net/componenthelp/index.html#/ManageLifetime_Method/00...
As you can see, it says objects are released during the Dispose process, which I take to mean when they go out of scope or when the ComReleaser itself goes out of scope (i.e. exiting a Using block).  It also states that ReleaseComObject is called until the reference count is 0, which is the same as calling FinalReleaseComObject.  Again, I'm not advising anyone not to use the ComReleaser class, I'm just saying that releasing the objects yourself is one sure-fire way of knowing exactly what your code is doing.
Also, the only time I've ever found I needed to explicitly release anything is when dealing with cursors and feature/row objects.  For everything else I just them go out of scope and be at the mercy of the garbage collector.
sapnas
... and sometimes a simple SetEmpty method will clear geometries and release memory.
The system wouldn't let me post my whole code block, so this will be the main code that had the issues.  My next post will be the beginning of the code.
            Try
                ' Using comReleaser As ESRI.ArcGIS.ADF.ComReleaser = New ESRI.ArcGIS.ADF.ComReleaser()
                pEnumFeat.Reset()
                'Dim pFCur As IFeatureCursor = Nothing
                    pLargestAdj = GetLargestAdjacent(sliverFeat, True, pSF, pFClass)
                        sliverFeat.Delete()
                        GC.Collect()
                        GC.WaitForPendingFinalizers()
                    Else
                    End If
                Loop
                'End Using
            End Try
            m_gdbPath = ""
            'refresh the selectionset on screen
            Dim pActiveView As IActiveView
            pActiveView = CType(pMap, IActiveView)
            pMxDoc.CurrentContentsView.Refresh(Nothing)
            pActiveView.Refresh()
            'Let the user know it completed successfully
            MsgBox("Complete")
            'Show the user how long it took to process
            Dim tElapsed As TimeSpan = DateTime.Now.Subtract(tStartTime)
            MsgBox(nCurRecNo.ToString + " records in: " + tElapsed.Hours.ToString + " hours " + tElapsed.Minutes.ToString + " minutes " + tElapsed.Seconds.ToString + " seconds.")
            m_pFLayer = Nothing
            MsgBox(ex.StackTrace)
            MsgBox(ex.Message)
        End Try
    End Sub
    Function GetLargestAdjacent(ByVal pFeat As IFeature, ByVal getSecondLargest As Boolean, ByVal pSF As ISpatialFilter, ByVal pFC As IFeatureClass) As IFeature
        'MsgBox("in get largest adjacent")
        Try
            'pFcur = pFC.Search(pSF, False)
            pFcur = pFC.Update(pSF, False)
            End If
                            pFcur.Flush()
                            'Runtime.InteropServices.Marshal.FinalReleaseComObject(pLargestFeat)
                        Else
                            End If
                        End If
                    End If
                    pFeat2 = Nothing
                    pFCur.Flush()
                    pFeat2 = pFCur.NextFeature
                Loop
                    'pFcur = m_pFLayer.FeatureClass.Search(pSF, False)
                    pFcur = m_pFLayer.FeatureClass.Update(pSF, False)
                                Else
                                    End If
                                End If
                            End If
                        End If
                        pFcur.Flush()
                    Loop
                End If
            End Using
        End Try
    End Function
        Marshal.FinalReleaseComObject(featureCursor)
        Marshal.FinalReleaseComObject(featureToUpdate)
        'Marshal.FinalReleaseComObject(fc)
    End Sub
    End Function
    Protected Overrides Sub OnUpdate()
        Enabled = My.ArcMap.Application IsNot Nothing
    End Sub
End Class
Imports System.Runtime.InteropServices
Imports System.Drawing
Imports ESRI.ArcGIS.ADF.BaseClasses
Imports ESRI.ArcGIS.ADF.CATIDs
Imports ESRI.ArcGIS.Framework
Imports ESRI.ArcGIS.ArcMapUI
Imports ESRI.ArcGIS.Carto
Imports ESRI.ArcGIS.Geodatabase
Imports ESRI.ArcGIS.Geoprocessing
Imports ESRI.ArcGIS.Geometry
Imports ESRI.ArcGIS.Editor
Imports ESRI.ArcGIS.esriSystem
Imports ESRI.ArcGIS.Catalog
Imports System.Windows.Forms
Public Class RElimAddinPB
    Inherits ESRI.ArcGIS.Desktop.AddIns.Button
    Public Sub New()
    End Sub
    Protected Overrides Sub OnClick()
        Try
            'TODO: Add elimSmallest.OnClick implementation
            Dim pMxDoc As IMxDocument = My.ArcMap.Document
            Dim pFrm As frmSelectLayer = New frmSelectLayer
            Dim pFClass As IFeatureClass = Nothing
            Dim pMap As IMap = pMxDoc.FocusMap
            Dim pEnumLayer As IEnumLayer = pMap.Layers
            m_Success = False
            'Get the selected layer and selection set from the selected layer's feature class
            Dim pLayer As ILayer = Nothing
            Dim pFLayer As IFeatureSelection = Nothing
            Dim pFCursor As IFeatureCursor = Nothing
            'gp.OverwriteOutput = True
            Dim uid As ESRI.ArcGIS.esriSystem.UID = Nothing
            uid = New UIDClass
            uid.Value = "esriEditor.Editor"
            Dim pEditor As IEditor = Nothing
            pEditor = CType(My.ArcMap.Application.FindExtensionByCLSID(uid), IEditor)
            'Add all the layers in the TOC to the form
            Try
                If pMap.LayerCount = 0 Then
                    Exit Sub
                End If
                pLayer = pEnumLayer.Next
                Do Until pLayer Is Nothing
                    pFrm.cboSelectLayer.Items.Add(pLayer.Name)
                Loop
                MsgBox("Error: " & ex.StackTrace)
            End Try
            m_pFLayer = Nothing
            'show the dialog which will allow the user to select a layer
            pFrm.ShowDialog()
            If Not m_Success = True Then
                Exit Sub
            End If
            ' Dim pDS As IDataset
            Dim factoryType As Type = Type.GetTypeFromProgID("esriDataSourcesGDB.FileGDBWorkspaceFactory")
            Dim workspaceFactory As IWorkspaceFactory = CType(Activator.CreateInstance(factoryType), IWorkspaceFactory)
            Dim workspace As IWorkspace = workspaceFactory.OpenFromFile(m_gdbPath, 0) 'm_gdbpath was set in frmSelectLayer
            If workspace Is Nothing Then
                MsgBox("Workspace doesn't exist!", MsgBoxStyle.Information, "RElimAddinPB_OnClick")
                Exit Sub
            End If
            ' Use the IFeatureWorkspace interface to open a feature class.
            Dim featureWorkspace As IFeatureWorkspace = CType(workspace, IFeatureWorkspace)
            'Open the feature class of the copied layer
            Dim featureClass As IFeatureClass = featureWorkspace.OpenFeatureClass(m_strLayerName & "_alt_elim")
            If featureClass Is Nothing Then
                MsgBox(m_gdbPath & "\" & m_strLayerName & "_alt_elim doesn't exist!", MsgBoxStyle.Information, "RElimAddinPB_OnClick")
                Exit Sub
            End If
            'Create new layer of copied layer and add it to arcmap
            Dim pNewFLayer As IFeatureLayer = New FeatureLayer
            pNewFLayer.FeatureClass = featureClass
            pNewFLayer.Name = m_strLayerName & "_alt_elim"
            pMap.AddLayer(pNewFLayer)
            m_pFLayer = pNewFLayer
            pFClass = m_pFLayer.FeatureClass
            'Get a reference to the newly added layer
            pEnumLayer = pMap.Layers
            pLayer = Nothing
                If pLayer.Name = pNewFLayer.Name Then
                    pNewFLayer = CType(pLayer, IFeatureLayer)
                    Exit Do
                End If
            Loop
            If Not Right(pNewFLayer.Name, 9) = "_alt_elim" Then
                MsgBox("Alternative Elimination layer not yet created!", MsgBoxStyle.Information, "RElimAddinPB_OnClick")
                m_strLayerName = ""
                m_pFLayer = Nothing
                m_gdbPath = ""
                Exit Sub
            End If
            'do a spatial select to transfer the selection from the original layer to the copied layer
            'Set up the geoprocessor to copy the dataset
            Dim gp As IGeoProcessor = New GeoProcessor
            Dim strParam As IVariantArray = New VarArray
            gp.SetEnvironmentValue("Workspace", m_gdbPath)
            'set the parameters for the copy tool
            strParam.Add(pNewFLayer.Name)
            strParam.Add("ARE_IDENTICAL_TO")
            strParam.Add(m_strLayerName)
            'execute the select by layer tool
            Dim results As IGeoProcessorResult = CType(gp.Execute("SelectLayerByLocation_Management", strParam, Nothing), IGeoProcessorResult)
            If results.Status <> ESRI.ArcGIS.esriSystem.esriJobStatus.esriJobSucceeded Then
                MsgBox("Failed to execute select by layer!", MsgBoxStyle.Information, "frmSelectLayer_btnRun_click")
                results = Nothing
                gp = Nothing
                Exit Sub
            End If
            gp = Nothing
            'My.ArcMap.Application.StatusBar.Message(0) = "Unselecting records from original layer."
            'Application.DoEvents()
            'Now unselect the features fromt the original layer
            Dim ppLayer As ILayer = Nothing
            Dim pFLayerSel As IFeatureSelection = Nothing
            Dim pNewerEnumLayer As IEnumLayer = Nothing
            pNewerEnumLayer = pMap.Layers
            ppLayer = pNewerEnumLayer.Next
            Do Until ppLayer Is Nothing
                If ppLayer.Name = m_strLayerName Then
                    If TypeOf ppLayer Is IFeatureLayer Then
                        pFLayerSel = CType(ppLayer, IFeatureSelection)
                        If pFLayerSel.SelectionSet.Count > 0 Then
                            pFLayerSel.Clear()
                        End If
                    End If
                End If
            Loop
            'Make sure features are selected in the layer
            Dim pWorkspace As IWorkspace2 = Nothing
            Dim pFLDS As IDataset = Nothing
            pFLayer = CType(m_pFLayer, IFeatureSelection)
            If pFLayer.SelectionSet.Count = 0 Then
                MsgBox("No features selected!  Must select features before using this tool", MsgBoxStyle.Information, "RElimAddinPB_OnClick")
                m_strLayerName = ""
                m_pFLayer = Nothing
                m_gdbPath = ""
                Exit Sub
            End If
            pFLDS = CType(pFLayer, IDataset)
            pWorkspace = CType(pFLDS.Workspace, IWorkspace2)
            pEditor.StartEditing(CType(pWorkspace, IWorkspace))
            'Start editing the workspace
            If pEditor.EditState = esriEditState.esriStateNotEditing Then
            End If
            Dim n As Integer
            n = pFLayer.SelectionSet.Count
            Dim nCurRecNo As Integer = 0
            Dim tStartTime As DateTime = Now
