Releasing memory using Marshal.FinalReleaseComObject
10199
23
03-07-2012 11:37 AM
USFS_AGOLAdministrator
Hi all,
I know this is alot of code, but you have to see the whole thing understand the problem. The code below is doing a Reverse Eliminate of sorts by looping through a selected set of sliver polygons, doing a spatial selection to find out what polygons are touching the slivers, getting the 2nd largest polygon that touches the sliver, and merging the sliver to the second largest polygon by unioning them together, and deleting the original sliver polygon.
It works beautifully well, except it bombs out after processing ~900 slivers with a memory error. I've tried everything I can think of to release the memory, as you will see below. Can anyone see anywhere I can release more memory?
Try
     Using comReleaser As ESRI.ArcGIS.ADF.ComReleaser = New ESRI.ArcGIS.ADF.ComReleaser()
Dim pFeat As IFeature = Nothing
Dim pEnumFeat As IEnumFeature = CType(pMap.FeatureSelection, IEnumFeature)
'Dim pEnumFeat As IEnumFeature = CType(pFLayer.SelectionSet, IEnumFeature)
pEnumFeat.Reset()
Dim pFCur As IFeatureCursor = Nothing
Dim pSF As ISpatialFilter
pSF = New SpatialFilter
Dim pTopoOp As ITopologicalOperator
Dim pLargestAdj As IFeature = Nothing
Dim sliverFeat As IFeature = Nothing
sliverFeat = pEnumFeat.Next
Do Until sliverFeat Is Nothing
'this is really the smallest
pLargestAdj = GetLargestAdjacent(sliverFeat, True, pSF, pFCur, pFClass)
If Not pLargestAdj Is Nothing Then
pTopoOp = CType(pLargestAdj.ShapeCopy, ITopologicalOperator)
pLargestAdj.Shape = pTopoOp.Union(sliverFeat.ShapeCopy)
updateFeature(m_pFLayer.FeatureClass, pLargestAdj.OID, pLargestAdj.Shape)
sliverFeat.Delete()
Marshal.FinalReleaseComObject(sliverFeat)
Marshal.FinalReleaseComObject(pTopoOp)
Marshal.FinalReleaseComObject(pLargestAdj)
Else
Debug.Print("nothing adjacent to: " & sliverFeat.OID)
End If
nCurRecNo = nCurRecNo + 1
My.ArcMap.Application.StatusBar.Message(0) = nCurRecNo.ToString & "/" & n.ToString & " records complete."
Application.DoEvents()
comReleaser.ManageLifetime(sliverFeat)
Loop
'Stop editing and save the edits
pEditor.StopEditing(True)
Runtime.InteropServices.Marshal.FinalReleaseComObject(pLargestAdj)
End Using
Catch ex As Exception
MsgBox("Error: " & ex.StackTrace, , "RElimAddinPB_onClick")
End Try
'!!!!!!!!!!!!!!!!!!!!!!!This function is where it bombs out after ~900 records!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Function GetLargestAdjacent(ByVal pFeat As IFeature, ByVal getSecondLargest As Boolean, ByVal pSF As ISpatialFilter, ByVal pFcur As IFeatureCursor, ByVal pFC As IFeatureClass) As IFeature
Try
pSF.Geometry = pFeat.Shape
pSF.SpatialRel = esriSpatialRelEnum.esriSpatialRelIntersects
pFcur = pFC.Search(pSF, False)
If pFC.FeatureCount(pSF) < 3 Then 'This is set if there is only polygons on one side of the sliver
getSecondLargest = False
End If
Dim pFeat2 As IFeature = Nothing, pLargestFeat As IFeature = Nothing
comReleaser.ManageLifetime(pFeat2)
comReleaser.ManageLifetime(pFcur)
Dim dMaxArea As Double = 0
pFeat2 = pFcur.NextFeature
Do Until pFeat2 Is Nothing 'This loop executes everytime, no matter if there are slivers on both sides or not
If Not pFeat2 Is pFeat Then
If pLargestFeat Is Nothing Then
pLargestFeat = pFeat2
dMaxArea = GetArea(CType(pFeat2.Shape, IArea))
Else
If GetArea(CType(pFeat2.Shape, IArea)) > dMaxArea Then
Runtime.InteropServices.Marshal.FinalReleaseComObject(pLargestFeat)
Runtime.InteropServices.Marshal.FinalReleaseComObject(pFeat2)
End If
End If
End If
pFcur.Flush()
Loop
Marshal.ReleaseComObject(pFcur)
'comReleaser.Dispose()
If getSecondLargest Then 'This loop will execute only if there are polygons on both sides of the sliver
'pFCur = pFC.Search(pSF, False)
pFcur = m_pFLayer.FeatureClass.Search(pSF, False)
Dim pSecondLargestFeat As IFeature = Nothing
Dim dSecondMaxArea As Double = 0
If Not pFeat2 Is pLargestFeat Then
If pSecondLargestFeat Is Nothing Then
pSecondLargestFeat = pFeat2
dSecondMaxArea = GetArea(CType(pFeat2.Shape, IArea))
Else
If GetArea(CType(pFeat2.Shape, IArea)) > dSecondMaxArea Then
End If
End If
End If
End If
pFcur.Flush()
Loop
pLargestFeat = pSecondLargestFeat
End If
GetLargestAdjacent = pLargestFeat
End Using
MsgBox(ex.Message, , "Ex routine")
MsgBox(ex.StackTrace, , "Ex routine")
GetLargestAdjacent = Nothing
End Try
End Function
Private Sub updateFeature(ByVal fc As IFeatureClass, ByVal oid As Integer, ByVal newGeom As IGeometry)
Dim queryFilter As IQueryFilter = New QueryFilter() With { _
.WhereClause = Convert.ToString(fc.OIDFieldName) & " = " & oid.ToString() _
Dim featureCursor As IFeatureCursor = fc.Update(queryFilter, False)
Dim featureToUpdate As IFeature = featureCursor.NextFeature()
featureToUpdate.Shape = newGeom
featureCursor.UpdateFeature(featureToUpdate)
Runtime.InteropServices.Marshal.ReleaseComObject(featureToUpdate)
featureCursor.Flush()
End Sub
Function GetArea(ByVal pArea As IArea) As Double
GetArea = pArea.Area
End Function
RichWawrzonek
Rich,
I tried intantiating the cursor and filter in the GetLargest Adjacent function to begin with, it still had the same problem.
Was this before you added all the ComReleaser stuff? It seems weird that you are creating an object in the main loop and releasing it in a sub function. Maybe create the feature cursor object in GetLargestAdjacent() and then force garbage collection in the main loop using this code:
GC.Collect() GC.WaitForPendingFinalizers()
More information on the GC class here:
http://msdn.microsoft.com/en-us/library/system.gc.aspx
RichWawrzonek
Are you getting the ArcMap 'Out of memory' error or something else?
I'm not sure why you are instantiating your feature cursor and spatial filter (pFCur, pSF) outside of the GetLargestAdjacent() function. They aren't used in the main loop. Try creating them in GetLargestAdjacent() and see if that helps. It's generally a bad idea to pass feature cursors around.
NeilClemmons
Honored Contributor
Could you edit this to use the CODE tags (the # button on the toolbar in the editing window) so that the code you posted is formatted correctly?
sapnas
I remember having memory issue with Union method in 9.3. Have you tried commenting pTopoOp.Union(sliverFeat.ShapeCopy)? This might help in narrowing down the issue.
Here is the code properly formatted:
            Try
                    pEnumFeat.Reset()
                            sliverFeat.Delete()
                        Else
                        End If
                    Loop
                End Using
            End Try
            m_gdbPath = ""
            'refresh the selectionset on screen
            Dim pActiveView As IActiveView
            pActiveView = CType(pMap, IActiveView)
            pMxDoc.CurrentContentsView.Refresh(Nothing)
            pActiveView.Refresh()
            'Let the user know it completed successfully
            MsgBox("Complete")
            'Show the user how long it took to process
            Dim tElapsed As TimeSpan = DateTime.Now.Subtract(tStartTime)
            MsgBox(nCurRecNo.ToString + " records in: " + tElapsed.Hours.ToString + " hours " + tElapsed.Minutes.ToString + " minutes " + tElapsed.Seconds.ToString + " seconds.")
            m_pFLayer = Nothing
            MsgBox(ex.StackTrace)
            MsgBox(ex.Message)
        End Try
    End Sub
        'MsgBox("in get largest adjacent")
        Try
            'pFcur = pFC.Search(pSF, False)
            pFcur = pFC.Update(pSF, False)
            'If m_pFLayer.FeatureClass.FeatureCount(pSF) < 3 Then
            '    getSecondLargest = False
            'End If
            End If
                            pFcur.Flush()
                            'Runtime.InteropServices.Marshal.FinalReleaseComObject(pLargestFeat)
                        Else
                            End If
                        End If
                    End If
                    pFcur.Flush()
                Loop
                    'pFcur = m_pFLayer.FeatureClass.Search(pSF, False)
                    pFcur = m_pFLayer.FeatureClass.Update(pSF, False)
                                Else
                                    End If
                                End If
                            End If
                        End If
                        pFcur.Flush()
                    Loop
                End If
            End Using
        End Try
    End Function
    End Sub
Rich,
When I commented this out, it ran much faster, but still errored out with a message:
"There is not enough memory"
But I will try commenting things out, to see what is causing it.  Thanks for the suggestion.
RichWawrzonek
Rich,
NeilClemmons
Honored Contributor
I would get rid of using the ComReleaser altogether.  Here is the proper way to get a cursor and loop through it as well as clean up the objects that it uses:
Dim featureCursor As IFeatureCursor = featureClass.Search(queryFilter, False)
Dim feature As IFeature = featureCursor.NextFeature
Do While feature IsNot Nothing
    ' do something with the feature
    FinalReleaseComObject(feature) ' release the feature before setting it to the next feature in the cursor
    feature = featureCursor.NextFeature
Loop
FinalReleaseComObject(featureCursor) ' release the cursor
Look through your code and make sure you're releasing every cursor as soon as you're done with it and that you're releasing all feature references as soon as you're done with them (including those used in loops as shown above).  This is most likely where you're getting your error from.
One of your functions returns an IFeature reference.  I would change this to return the feature's geometry because that's what you're actually needing from the feature.
Post your updated code if you're still having problems.
sapnas
Have you tried trouble shooting the issue  by  monitoring the memory usage in taskmgr while stepping through each statement of your code?
