How to store elements of IMap(IGraphicsContainer) as BinaryData format in SQL ?
4110
7
10-16-2012 11:06 PM
TaiBui
I am having an IMap on PageLayoutControl that includes elements: Lines, Text,... (Please see attached screenshot).
[ATTACH=CONFIG]18473[/ATTACH]
How I can stores these elements as Binary Data format (Image type) in a SQL table ? And, I can load data from database into IMap, then still can move these elements.
Thanks and regards,
TaiBui
Are there anyone can help me ?
ThavitinaiduGulivindala
I belive BinaryData in SQL is nothing but BLOB esri field format.
If so, the elements can be stored into BLOB fields using IPersistStream interface. You can look for an article to find a way to store the data using
IMemoryBlobStream and
IPersistStream interfaces.
TaiBui
Thank you. Could you please give a code example for this ?
TaiBui
Hi, I tried to use the below codes to save and load elements of IMap, but I got the error: Error HRESULT E_FAIL has been returned from a call to a COM component
when calling the load function.
Do have anyone know how to fix it ?
public class Test
  IStream stream;
  IMap myMap;
  void Save()
    IPersistStream perStream;
    IMemoryBlobStream memoryStream = new MemoryBlobStreamClass();
    stream = memoryStream as IStream;
    perStream = (IPersistStream ) myMap ;
    perStream.Save(stream, 0);
  void Load()
     IPersistStream pstm = new MapClass();
     pstm.Load(stream); **// throw error: Error HRESULT E_FAIL has been returned from a call to a COM component.**
     myMap = (IMap)pstm;
TaiBui
I found out the way to store elements (of a MapFrame) into Image and load again by using the below codes:
void Save (AxPageLayoutControl pageControl)
                IGraphicsContainer graphicsContainer = pageControl.ActiveView.GraphicsContainer;
                graphicsContainer.Reset();
                IElement pElement = graphicsContainer.Next();
                while (pElement != null)
                    if (pElement is IMapFrame)
                        perStream = (IPersistStream)pElement ;
                        perStream.Save(memoryStream, 0);
                        memoryStream.SaveToFile("C:/image.bmp");
                        break;
void Load (AxPageLayoutControl pageControl)
                    memoryStream.LoadFromFile("C:/image.bmp");
                    perStream = (IPersistStream)pElement;
                    perStream.Load(memoryStream);
                    IMapFrame frame = new MapFrameClass();
                    frame   = (IMapFrame)perStream;
                    pElement = (IElement)frame;
                    break;
            pageControl.ActiveView.PartialRefresh(esriViewDrawPhase.esriViewGraphics, null, null);
But, I am finding a way to convert IPersistStream or IMemoryBlobStream to byte[] (binary format), so I can store in the SQL Server and load it later.
Are there anyone know this ?
Thanks and regards,
Cristian_Galindo
                        break;
                    break;
Thanks and regards,
this is another kind of situation, I have been struggling with something like that, but i cannot save the map directly into the database, so i first save the map to a file, and then save the file into the database, it was the workaround that i found to solve it.
Reading your code, you are trying to save a bitmap of the map (a graphic representation) not the map per se....aren't you?
TaiBui
Could you show me the codes that you used for this (I tried it, but not successful):
For saving directly into the database, I found out a solution (using IXMLStream to save to byte[], then store in database). For example:
IXMLStream xmlStream = new XMLStreamClass();
IStream stre = (IStream)xmlStream;
perStream.Save(stre, 0);
byte[] map = xmlStream.SaveToBytes();
// insert "map" into database
I want to save all elements of IGraphicsContainer into database, then can load later.
