How to save an IMap (or IGraphicsContainer) as an Image (such as: jpg, png...) ?
6290
10
09-30-2012 06:07 AM
TaiBui
I am having an IMap (AxPageLayoutControl.ActiveView.FocusMap) that includes some elements (Text, lines,...)
And, I want to create an Image (such as: jpg, png) that show all objects of the IMap (using C#, Visual Studio).
Do you know how to do that ?
Thanks and regards,
Tai
TaiBui
how do you figure the screen resolution?
Hi Xtian79,
I found out another way, please see the link: http://forums.arcgis.com/threads/69207-How-to-store-elements-of-IMap%28IGraphicsContainer%29-as-Bina...
Kind regards,
Cristian_Galindo
Hi, basically one way is to draw layer by layer in an image object,  then export it
                private static IDisplay myDisplay;
                private static Image myMapImage;
                Graphics g = Graphics.FromImage(myMapImage);
                g.Clear(Color.Transparent);
                myDisplay.StartDrawing(g.GetHdc().ToInt32(), 0);
                for (int i = Map.LayerCount - 1; i >= 0; i--)
                    ILayer layer = MapControl.get_Layer(i);
                    layer.Draw(esriDrawPhase.esriDPGeography, myDisplay, null);
                myDisplay.FinishDrawing();
                g.ReleaseHdc();
I hope this is helpful for you
TaiBui
                g.ReleaseHdc();
Thank you. But there is an error: Use of unassigned local variable 'myMapImage'
Kind regards,
Tai
TaiBui
I am thinking about converting elements of IMap into RasterDataset (in geodatabase). Then, export RasterDataset into Image. But I haven't known how to do that. Are there anyone can help ?
Please see my below screenshot:
[ATTACH=CONFIG]18127[/ATTACH]
Cristian_Galindo
Kind regards,
Tai
you are rigth, that's my mistake, you have to initialize the variable....
TaiBui
Could you please tell me how to do that ?
TaiBui
After searching on the internet. I found the solution for this and used the below codes to export IMap to image:
private void SaveImapAsJpg(IMap map, string filePath)
            IExport pExport = new ExportJPEGClass();
            IActiveView activeView = map as IActiveView;
            pExport.ExportFileName = filePath;
            pExport.Resolution = 100;
            tagRECT exportRect = activeView .ExportFrame  ;
            IEnvelope pPixelBoundsEnv = new EnvelopeClass();
            pPixelBoundsEnv.PutCoords(exportRECT.left, exportRECT.bottom, exportRECT.right, exportRECT.top);
            pExport.PixelBounds = pPixelBoundsEnv;
            int hDC;
            hDC = pExport.StartExporting();
            activeView.Output(hDC, (int)pExport.Resolution, ref exportRECT, activeView.FullExtent, null);
            pExport.FinishExporting();
            pExport.Cleanup();
Please see the result in image1
But the Image is not same as IMap. When I replace the italic codes by below codes, the image is good (I am not sure why ?):
            System.Int32 screenResolution = 30;
            System.Int32 outputResolution = 200;
            pExport.Resolution = outputResolution;
            ESRI.ArcGIS.Display.tagRECT exportRECT;
            exportRECT.left = 0;
            exportRECT.top = 0;
            exportRECT.right = activeView.ExportFrame.right * (outputResolution / screenResolution);
            exportRECT.bottom = activeView.ExportFrame.bottom * (outputResolution / screenResolution);
Please see the result in image2
[ATTACH=CONFIG]18181[/ATTACH]
[ATTACH=CONFIG]18182[/ATTACH]
Cristian_Galindo
hi,
            exportRECT.top = 0;
TaiBui
Hi Xtian79,
Kind regards,
Cristian_Galindo
Hi Xtian79,
Kind regards,
Hi!!!,
in the solution that you propose how do you figure the value of the screen resolution?, or is it just a random value? i trying to export an image to the printer, that information would be useful
