How to know ArcGis version in C#
3210
10-30-2012 03:20 AM
MuhammetCiftci
I have a problem since the last version of ArcGis, the 10.1, was released.
My problem is the following :
When using the DataManagement Clip tool, there's a parameter named nodata_value which was a Double in ArcGis 10 and now it's a string. So when someone uses my program with ArcGis 10.1, he gets this error : System.MissingMethodException: Method not found: 'Void ESRI.ArcGIS.DataManagementTools.Clip.set_nodata_value(Double)'.
ArcGis 10.1 : http://resources.arcgis.com/en/help/main/10.1/index.html#//00170000009n000000
ArcGis 10.0 : http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//00170000009n000000
So a solution may be to check the current version of ArcGis and give the good parameter :
if(arcgis10_1)
   nodata_value = myDoubleValue.ToString();
else
   nodata_value = myDoubleValue;
But I don't know how to recognize in which version I am.
Thank you for your help.
M. Ciftci
MuhammetCiftci
I've found something :
var runtimes = ESRI.ArcGIS.RuntimeManager.InstalledRuntimes;
foreach (var info in runtimes)
    System.Diagnostics.Debug.Print(info.Product.ToString());
    System.Diagnostics.Debug.Print(info.Version);
    System.Diagnostics.Debug.Print(info.Path);
The assembly is ESRI.ArcGIS.Version
MuhammetCiftci
