Error:Class not registered (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG))
612
10-30-2012 06:18 PM
TaiBui
I am trying to save (and load) IPersistStream into byte[] format in SQL Server. But, I got an error: Class not registered (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG)) in the loading function.
Please see my below codes:
public void save(AxPageLayoutControl pageControl)
            IPersistStream perStream;
            IMemoryBlobStream mebStream = new MemoryBlobStreamClass();
            IGraphicsContainer graphicsContainer = pageControl.ActiveView.GraphicsContainer;
            graphicsContainer.Reset();
            IElement pElement = graphicsContainer.Next();
            while (pElement != null)
                if (pElement is IMapFrame)
                    perStream = (IPersistStream)pElement;
                    perStream.Save(mebStream, 0);
                    byte[] map = new byte[mebStream.Size];
                    mebStream.AttachToMemory(map [0], (uint)map .Length, 0);
                    // codes to insert "map" into a sql table
                    break;
For loading:
public void load(AxPageLayoutControl pageControl)
                    // Get byte[] data from database (execute a select statement)
                    byte[] map = GetDataFromDatabase();
                    mebStream.ImportFromMemory(map [0], (uint)map .Length);
                    perStream.Load(mebStream);  // Throw error
                    IMapFrame frame = new MapFrameClass();
                    frame = (IMapFrame)perStream;
                    pElement = (IElement)frame;
                    break;
            pageControl.ActiveView.PartialRefresh(esriViewDrawPhase.esriViewGraphics, null, null);
Are there anyone can help ?
Thanks and regards,
