Get field attribute problem
3866
10
06-20-2012 06:04 AM
DaveCouture
After selecting a feature through a query, I'd like a message box to pop up with 2 field values. This is what I have (in red):
 Public Sub SelectMapFeaturesByAttributeQuery(ByVal activeView As IActiveView, ByVal featureLayer As IFeatureLayer, ByVal whereClause As System.String)
        If activeView Is Nothing OrElse featureLayer Is Nothing OrElse whereClause Is Nothing Then
            Return
        End If
        Dim featureSelection As IFeatureSelection = TryCast(featureLayer, IFeatureSelection) ' Dynamic Cast
        ' Set up the query
        Dim queryFilter As IQueryFilter = New QueryFilterClass
        queryFilter.WhereClause = whereClause
        ' Invalidate only the selection cache. Flag the original selection
        activeView.PartialRefresh(esriViewDrawPhase.esriViewGeoSelection, Nothing, Nothing)
        ' Perform the selection
        featureSelection.SelectFeatures(queryFilter, esriSelectionResultEnum.esriSelectionResultNew, False)
        ' If PID found, Flag the new selection
        If featureSelection.SelectionSet.Count() = 0 Then
            MsgBox("Can't find the PID")
        Else
        End If
        ' Zoom to selected feature, if checkmarked
        If CheckBox1.CheckState = 1 Then
            Dim pUID As New UID
            pUID.Value = "esriArcMapUI.ZoomToSelectedCommand"
            My.ArcMap.Application.Document.CommandBars.Find(pUID).Execute()
        End If
        ' Display Owner's Name and PAN in message box
        Dim cursor As IFeatureCursor
        Dim feature As IFeature
        Dim patspan As String
        Dim taxname As String
        featureSelection.SelectionSet.Search(Nothing, False, cursor)
        feature = cursor.NextFeature
        patspan = feature.Fields.FindField("patspan")
        taxname = feature.Fields.FindField("taxname")
        Do Until feature Is Nothing
            MsgBox("PAN: " + feature.Value(patspan) + vbNewLine + "Owner's Name: " + feature.Value(taxname))
        Loop
 End Sub
End Class
KenBuja
MVP Esteemed Contributor
You should put your query filter into the Search
cursor = featureLayer.Search(queryFilter, False)
BruceNielsen
The variables 'patspan' and 'taxname' need to be declared as Integer.
DaveCouture
Thanks Bruce, that fixed one problem. Now I get the MessageBox, but I get no values. I believe the problem is with the cursor, because it says the cursor is use without being assigned a value, in the following statement:
BruceNielsen
Try changing 'cursor' from IFeatureCursor to ICursor.
DaveCouture
I got it to work.
I changed this:
with this:
cursor = featureLayer.Search(Nothing, False)
But, I'm getting the values of the first row, not the selected feature.
BruceNielsen
Whatever works. I'm still learning too.
DaveCouture
haha, it's not really working, because it returns the values of the first row, in the attribute table.  I just want the values of the selected feature.
KenBuja
DaveCouture
Gosh, it seems so obvious now..lol  Thanks a bunch, Ken!
JoeHershman
In this line of code that 'works' you are searching the entire FeatureClass not the SelectionSet
I think what you are missing in your previous code is explicitly initializing the ICursor.  I am not a VB guy in C# it would be
    ICursor cursor = null;
    featureSelection.SelectionSet.Search(null, false, cursor)
Something like this in VB
    Dim cursor as ICursor
    cursor = Nothing
Hope that helps
-Joe
