Error stopping an edit session with save edits
3674
06-20-2012 08:17 AM
AlexanderGray
Honored Contributor
Hello there, I have this intermittent problem with my ArcMap application.
I get this error:
"System.Runtime.InteropServices.COMException (0x80040554): Error stopping an edit session with save edits [FCAnno]"
If I try to do stop editing manually I get the same message (minus the comrexception)
If I save the edit session with the save edits button, it looks like it works and then I can manually stop the edit session.  However, when I do that all my features in the FCAnno feature class are lost and also some in an unrelated (in same feature dataset) line feature class also.
The edit session is in a file gdb on the local machine.  If I grab a back-up of the file gdb, do some edits and save it, it works ok.
