Cannot load Arcobject java plugin to eclipse (64 bit)
6910
12
07-16-2013 08:33 AM
IshanKaushik
I installed following setup available in ArcGis Desktop installer
1) ArcGis Desktop.
2) Under ArcGis Developer Resources --> ArcObject SDK for Java Platform.
This installlation was done on window 7 64 bit computer.
My problem is i am not able to install the eclipse pluggin.
Do i am require to install java runtime SDK ?
But that installation is not available in ArcGis Destop installation manager.
Can i develope java standalone application in eclipse with arcGis Destop evironment of 64 bit system?
Or is it because java arcObject 10 is not compatible with 64 bit system.
EricBader
Honored Contributor
Yes, the system requirements may be slightly confusing with respect to the 64-bit thing.
ArcObjects can run on a 64-bit machine, but ONLY as a 32-bit application.
ArcObjects cannot be loaded into a 64-bit Java process.
Therefore, on a 64-bit machine, you will need to use 32-bit JDK/JVM for developing and running your ArcObjects Java-based applications.
The ArcGIS Runtime SDK for Java SE, which is what this forum is about, CAN run in pure 64-bit Java, and your applications built with this SDK CAN run as native 64-bit applications (or 32-bit if you want), because the libraries are not based on ArcObjects.
The ArcGIS Runtime SDK for Java SE is a completely different SDK product and toolset, a different technology, than the ArcObjects SDK for Java.
Does this help?
I can understand the confusion, but I do hope this helps.
IshanKaushik
Thanks to the comment now my java application is working on eclipse 64 bit system.
Just a follow up to th question , i have editor license and its working fine on eclipse , but when i export and run the jar file through command line , i am getting error ---
"Unable to initialize ArcObjects environment.
AutomationException: 0x800401f5 - The specified product or version does not exis
t on this machine. in 'ArcGISVersion.Version'"
P.S
Following is the engine code that i am using ---
 EngineInitializer.initializeEngine();
   //Initialize ArcGIS license
   AoInitialize aoInit = new AoInitialize();
   initializeArcGISLicenses(aoInit);
   SdeOrPgdb accessFileGDB = new SdeOrPgdb();
                                       accessFileGDB.openFromFile_pGDB_Workspace();
                System.out.println("Done.");
   //Ensure any ESRI libraries are unloaded in the correct order
   aoInit.shutdown();
              }catch(Exception e){
   System.out.println("Error: " + e.getMessage());
   System.out.println("Sample failed.  Exiting...");
   e.printStackTrace();
   System.exit(-1);
  private static void initializeArcGISLicenses(AoInitialize aoInit) {
  try {
   if (aoInit.isProductCodeAvailable(esriLicenseProductCode.esriLicenseProductCodeEngine)
     == esriLicenseStatus.esriLicenseAvailable)
    aoInit.initialize(esriLicenseProductCode.esriLicenseProductCodeEngine);
   else if (aoInit.isProductCodeAvailable(esriLicenseProductCode.esriLicenseProductCodeArcView)
    aoInit.initialize(esriLicenseProductCode.esriLicenseProductCodeArcView);
   else if (aoInit.isProductCodeAvailable(esriLicenseProductCode.esriLicenseProductCodeArcEditor)
    aoInit.initialize(esriLicenseProductCode.esriLicenseProductCodeArcEditor);
   else if (aoInit.isProductCodeAvailable(esriLicenseProductCode.esriLicenseProductCodeArcInfo)
    aoInit.initialize(esriLicenseProductCode.esriLicenseProductCodeArcInfo);
   else{
    System.err.println("Could not initialize an Engine or ArcView or ArcInfo or ArcEditor license. Exiting application.");
    System.exit(-1);
  } catch (Exception e) {e.printStackTrace();}
SachinKanaujia
Make sure that the required environment variables are set correctly before launching the jar. Also <Arcgishome>/bin is in your PATH
