Cannot load Arcobject java plugin to eclipse (64 bit)
6896
12
07-16-2013 08:33 AM
IshanKaushik
I installed following setup available in ArcGis Desktop installer
1) ArcGis Desktop.
2) Under ArcGis Developer Resources --> ArcObject SDK for Java Platform.
This installlation was done on window 7 64 bit computer.
My problem is i am not able to install the eclipse pluggin.
Do i am require to install java runtime SDK ?
But that installation is not available in ArcGis Destop installation manager.
Can i develope java standalone application in eclipse with arcGis Destop evironment of 64 bit system?
Or is it because java arcObject 10 is not compatible with 64 bit system.
SachinKanaujia
Can you verify if its taking the 32 bit JRE? To be absolutely sure I would recommend you to run in from command line. Set the java path, ArcGIS related path, "check the java -version" and then run some simple test program. Its clearly an issue where its not able to load a 32 bit dll
SachinKanaujia
Yes you need to use a 32 bit version of java. Here is the System requirement.
http://resources.arcgis.com/content/arcgissdks/10.0/system-requirements
If you are developing some console based jobs etc then this should be sufficient but if there is something that requires a UI component then you need to use ArcGIS Engine.
IshanKaushik
Thanks , for response but there it says that Windows Vista Ultimate, Enterprise, Business, Home Premium (32-bit and 64-bit (EM64T)) are supported for ArcObjects SDK for the Java Platform.
I am using same comfrigration Window 7 and java sdk installed . There i can't see anything specific to engine and destop environment . Furthermore you said that engine environment is required if GUI is there , like a standalone application . But in documentation , at following link
http://help.arcgis.com/en/sdk/10.0/java_ao_adf/conceptualhelp/engine/index.html#//0001000003n1000000
, They have shown two bootsrap methord , one for "AGSENGINEJAVA" thats for Engine environment and other "AGSDESKTOPJAVA" for destop environment .
I am getting confused whats the dilema here , can you please clear it .
The basic problem is i want to use ArcGis Destop License environment , and create an java standalone application on 64 bit system.
IshanKaushik
OK , i somehow instal plugin to eclipse but the problem is not resolved yet .
While running my application following error comes in console of eclipse
"Could not load native libraries.
java.lang.UnsatisfiedLinkError: C:\Program Files (x86)\ArcGIS\Desktop10.0\Bin\ntvinv.dll: Can't load IA 32-bit .dll on a AMD 64-bit platform"
What does that mean ???
SachinKanaujia
Looks like it is still picking up the 64 bit JRE. Can you check and make sure you run it on a 32 bit JRE
IshanKaushik
That mean i am require to have both 32 bit and 64 bit java jdk installed on my system ?
IshanKaushik
Ok , i installed the 32 bid jdk and provided eclipse to run through 32 bit jre in run configration . But the error is same as mentioned above.
SachinKanaujia
IshanKaushik
I tried to run via 32 bit sdk , it is compiling it but again in my code where i initialise the licence as
"EngineInitializer.initializeEngine();"
It promts exception of "Unable to initialize ArcObjects environment.
AutomationException: 0x800401f5 - The specified product or version does not exis
t on this machine. in 'ArcGISVersion.Version' ".
Do i need to change my code to smthing initialising Desktop not Engine ?
Or as u said earlier standalone tool wont work without engine environment ?
SachinKanaujia
Can you provide the Initialization code you are using? It appears you are not binding your Arcobjects environment correctly to the available product on your machine.
