Why is the HTML popup tool greyed out?
4062
9
06-19-2018 03:39 AM
TomRuff
I'm attempting to show photo attachments in a html popup but I can't get the html popup tool to activate. I've selected show html popups in the feature properties of the layer. But I'm unsure how to progress.
Any ideas?
XanderBakker
Esri Esteemed Contributor
Can you include a screenshot of the situation and mention what software you are using, including the version?
TomRuff
Absolutely, Im using Arcmap 10.5
The screenshot shows the greyed out button in the top left.
Cheers,
Tom
XanderBakker
To start, the HTML pop-up won't work in Layout view:
Switch to Data view:
... and please include a screenshot of the layer properties to see how you defined the html pop-up.
TomRuff
Great thank you it was that simple. Unfortunately it didnt achieve what I wanted as I thought I could leave them on the layout view and print the map with photos as labels essentially. Do you know of any way I can show attachments as labels or something that achieves as similar effect?
XanderBakker
In ArcGIS Online, you could do something like this ( Show Attachments in Web Map Popup ) to include the photo in the pop-up.  If your goal is to create a hardcopy map and show the photos on the layout, you can include them manually and add a line to connect the photo to the location. This will only be a solution if you have  a small number of photos to show on the layout. How many do you have?
TomRuff
I have a large number of photos taken on collector for trees in a forest. Ideally I want an arcmap drawing with several pages of dots each dot labelled by a photo which I have as attachments for the dots (similar to the screenshot but with multiple trees on one page).
Is this possible? Doing it manually would be a pain. I assume it could be done with python if the placement of pictures in the layout view can be automated?
XanderBakker
Nowadays it is more common to share a web map or web App containing the data so that others can explore the content or create a StoryMap.
However if only a hardcopy map works for you, then you could use data driven pages: How To: Add dynamic images to a map document with attachments from Data Driven Pages and as you mentioned with Python there is a lot possible. Please note that Python will not create new elements on your layout, but it can modify existing ones. So you could have a layout and include dummy (white) images in a certain area and replace the image with the photo using Python. This will require some heavy programming...
TomRuff
Yes this is as close as I've gotten using data driven pages. I'll look into thanks very much for your help.
xiaobingzhu
I made the same mistakes hahhaha
