Share Toolbox
2043
04-07-2021 12:14 PM
StanislavaV
I already finished my ModelBuilder which is saved in Toolbox. I created it in ArcGIS PRO and I need to share it with some people, who don´t have ArcGIS PRO, they have just ArcMap 10.2 so I saved it as "10.1./10.2 Toolbox, but when I share it, it shows only Toolbox and models are nowhere.....
I also tried open that  saved 10.1./10.2 Toolbox in ArcGIS PRO and also empty..
DanPatterson
MVP Esteemed Contributor
You were following this?
ModelBuilder: migration to ArcGIS Pro—ArcGIS Pro | Documentation
Did you try Consolidate Toolbox?
... sort of retired...
JayantaPoddar
Check if one of the following works for you.
1. Create a new toolbox > Save as 10.1/10.2 toolbox > Copy the scripts from original toolbox to the newly saved toolbox (or save your script from ModelBuilder in this newly saved toolbox).
or
2. Ask the ArcMap user to create a blank toolbox and share with you > Copy the scripts in the toolbox.
Think Location
StanislavaV
well I tried yours suggestions but none of them worked 😞 that tbx is still empty...without those models
