parameters of a map service are stored in an MXD and cannot be changed?
577
04-20-2020 11:42 AM
DylanTrerise
I am using ArcMap to publish services online so that they can be used by the JavaScript API.
It appears as if parameters of a map service are stored in an MXD the first time you publish the service and that, if you subsequently make changes to a map service, you cannot publish the mxd again since those changes are not incorporated into the MXD and the service fails to publish.  So, is there a way of updating the service parameters once you have published the service?
Right now I am having to create completely new maps to be able to publish.
Thanks!
