Need help with ArcGIS desktop
3470
6
07-19-2020 04:12 AM
luzelaDAFLLA1
Hello from Luzela,
I'm facing a problem as trying to do some spatial analysis. I get this message:
ERROR
updateParameters Syntax Error: Runtime error Traceback (most recent call last): File "c:\program files (x86)\arcgis\desktop10.8\ArcToolbox\Toolboxes\Spatial Statistics Tools.tbx#ClustersOutliers_stats.UpdateParameters.py", line 5, in File "c:\program files (x86)\arcgis\desktop10.8\arcpy\arcpy\__init__.py", line 34, in import arcpy.utils as utils AttributeError: 'module' object has no attribute 'utils'
I'm not familiar at all with coding, I just know how to use ArcGIS desktop to make my maps so any help is more than welcomed.
Thank you in advance
Luzela
DanPatterson
MVP Esteemed Contributor
You have a license for the Spatial Statistics extension?
Were you using the toolbox in arctoolbox? and if so what were the parameters you used?
... sort of retired...
luzelaDAFLLA1
Hello Dan,
Thanks for answering.
Well, I do have license for the Spatial Statistics extension. I'm using
arctoolbox and I was trying to proceed mapping Clusters/ Hot Spot Analysis
Even when I tried to proceed with moran's I, I received the same message
Στις Κυρ, 19 Ιουλ 2020 στις 3:54 μ.μ., ο/η Dan Patterson <[email protected]>
έγραψε:
GeoNet, The Esri Community | GIS and Geospatial Professional Community
<https://community.esri.com/?et=watches.email.thread>
Re: Need help with ArcGIS desktop
reply from Dan Patterson
<https://community.esri.com/people/danretired?et=watches.email.thread> in
ArcMap - View the full discussion
<https://community.esri.com/message/941938-re-need-help-with-arcgis-desktop?commentID=941938&et=watches.email.thread#comment-941938>
luzelaDAFLLA1
Here is what I get.....
Στις Κυρ, 19 Ιουλ 2020 στις 6:43 μ.μ., ο/η luzela luzela <
[email protected]> έγραψε:
Hello Dan,
έγραψε:
>> in ArcMap - View the full discussion
DanPatterson
What parameters are you using in the tool?  That is what is important.
Some tools have license restrictions, although the tool you were trying to run doesn't appear to have one
Spatial Statistics toolbox licensing—Help | Documentation
KoryKramer
Esri Community Moderator
Thanks for pointing to the Spatial Statistics toolbox licensing help, Dan!  I was about to do the same in response to the above Q & A about having an 'extension' or license for these tools.  Almost everything is available with a Basic license!
AnkitaBakshi
Hi Luzela,
As Dan and Kory mentioned, you don't need a license to run these Spatial Statistics Tools. I am wondering if you changed your python environment? Did you clone the environment or install anything in Python?
You can also try to delete the local caches and see if that changes anything. The cache by default can be found at this path %localappdata%\ESRI\Local Caches on your machine.
Can you also provide the parameters you were using in the tool so that we can try to reproduce this error and give you a solution?
Thanks!
Ankita
