Highlighted path turns solid on PDF.
916
09-29-2022 12:29 PM
RobertSliwinski
I've created a simple map with a highlighted path over a street, on a layer of satellite imagery set to 40% transparency. When I export to PDF, or write a PDF file in any way, the path turns solid.
Has anyone experienced this and/or have a suggested fix?
Thank  you,
Robert
RhettZufelt
MVP Notable Contributor
ArcMap has some issues going to PDF when there are transparencies set on layer(s).  Sometimes if you make sure any layers with transparency (even if not turned on) are at the BOTTOM of the TOC, it will resolve this issue.
R_
