Editing Attribute Values
1779
10-12-2022 04:07 AM
JD1016
Hello,
I have a parcel attribute table with a field containing addresses.  In several instances, it appears the street type designation has been left off.  For instance, "101 N Maple" should actually be "101 N Maple Avenue".
Is there a way, without having to go through each record in the attribute table, to add the word "Avenue" every time there is a "N Maple" occurrence?
Thank you in advance!
Jeff
2 Solutions
Kara_Shindle
I can think of a Python way and a non-Python way.  Let's start with the non-Python one.
I would select by attribute all records that have "101 N Maple" in them.  Then, change your attribute view to only the selected features, and do a Field Calculator session on only your selected values.
In field calculator, you can calculate a field using it's existing values.  So if your field name is something like
!Street!
Then your expression will be something like
!Street! + ' Avenue'
Notice I added a space before avenue in the string you are adding on, but that is dependent on if you have a space already in there or not.
Make sure you chose the Python and doublecheck your edits before you save everything to make sure it worked.
Kara_Shindle
Yes, I would use your wildcard character and the LIKE operator to build a SQL Query.  In ArcMap, that is the percent sign or %
Here's an article to get you started. https://desktop.arcgis.com/en/arcmap/latest/map/working-with-layers/building-a-query-expression.htm#...
I'm searching for all rows that in my street address field that have the word Church in them.  I put the wildcard before AND after church, because I know it has street numbers and road types on either side of the road name I'm looking for.
SITUSAddress1 LIKE '%CHURCH%'
Kara_Shindle
!Street!
JD1016
Hi Kara,
Your code suggestion worked perfectly!
As a follow-up, is there a way to select all instances of the words "N Maple"?  Otherwise, I will have to manually select 101 N Maple, 102 N Maple, 103 N Maple,...you get the idea.
Thanks.
Jeff
Kara_Shindle
JD1016
PERFECT!
I had employed the use of the LIKE operator with the percent sign before but I had the percent "only" at the end of the code and therefore it would look for those beginning with that instead of ending.  In adding the other %, everything was selected regardless of position.
Thank you, Kara!
