I am trying to open my attribute table from Arcmap 10.5, but this one can't open and a get this message ''ArcMap 10.5 will not display the Attribute Table dialog box''. I tried this option Problem: ArcMap will not display the Attribute Table dialog box for a layer, yet it's not working. Can someone help me to fix this out. Thanks
I would try renaming the Normal.mxt. To do this:
Hi Marie,
What type of data are you working with (i.e. shapefile, File Geodatabase feature class, Enterprise Geodatabase feature class)? Can you try importing the data into a new File Geodatabase and then see if you can open the attribute table?
Hello Jake,
Thanks for your help. I'm using a shapefile, I've import the shapefile into a File Geodatabase but still the attribute table doesn't display
Can you send a screen shot of ArcMap?
Thanks a lot Jake! It was a little bit tricky to find the AppData on computer but I definitely found it and It worked out
Having to kill the normal.mxt is an infuriating fix. Having to re-create my customized interface is a total hassle. At 10.6 should this still really be happening? Of course not!
Thank you! It works for me. 122320
ArcGIS 10.7 and counting... This is still the solution! Unbelievable. ESRI please fix by including an 'Attribute Table" view open/close option in 'Customise' or Window tab? It's frustrating to accidently lose an attribute table, then have to reset the .mxt and lose all settings to get it back.
At 10.8.2 it happens as well.
Can confirm! Was forced to use Pro to geocode a table of addresses, then when trying to look at the geocoded shapefile in ArcMap, the attribute table does not want to display.
Performed the suggested fix in this thread...and it fixed the issue for me (ArcGIS Desktop 10.8.2). Very bizarre.
