ArcMap has been opening a frozen map for days
3759
05-03-2021 11:56 AM
TaraSmith
I use ArcMap online through Citrix.  Last Thursday I was working on a project when the map froze in the afternoon.  I force shut down, logged off citrix, and restarted the computer.  When I tried to open ArcMap again, it opened the same map, still frozen, with no other options.  I have tried on multiple different browsers, I have run any and all computer updates, and I have cleared my download history.  The computer has been shut off and restarted a number of times since the initial freeze.  It has now been three days that ArcMap has been stuck on this frozen map and I don't know how to fix it.  Any ideas?
Tags (1)
BillFox
MVP Notable Contributor
TaraSmith
No luck... thanks for the suggestion
BillFox
maybe kill the process and rename the mxd file
Town_ofFarragut
I realize this is really late, but if you are in the frozen map and do Control + F1 it will bring up the citrix task manager and you can kill the map.  Took 8 years for someone to tell this to me and it was saved the day many times! Good Luck!
JessieCreech
For anyone who finds this thread.. the Control +F1 option works!! Even if you have closed out. Just try to reopen and when ArcMap tries to open the frozen map click Control +F1 and end all the tasks. Reopen ArcMap and it'll start fresh. Thank you!
