Using Collector from Workforce
3519
10
08-21-2019 08:21 AM
BrianBulla
Honored Contributor
I've created a Workforce project, and can see my Dispatcher and Worker maps from the projects Overview tab.  I am able to assign tasks through the Dispatcher map without any problems.
I'm using a Pixel 3 to run Workforce in the field.  I can see assigned tasks, but when I click on 'Collect at Assignment' to open up Collector, I get a "Map not found:  Make sure the map is shared with you." message come up.
It seems like my sharing permissions are setup correctly though, so I don't know what is going on.  Any ideas on things to try??
Kylie
by Esri Regular Contributor
The accounts for Collector and Workforce are separate (meaning that signing in to one doesn't sign you in to the other), so make sure you are signed in to both apps with the correct accounts. For Collector, maps need to be either authored by you, or share with a group of which you are a member (not just shared with the organization). You might want to verify that the map is shared in that way. Also, the map opened by Collector is a different map than Workforce uses, so access in Workforce doesn't guarantee sharing is set up right for the map used in Collector. The project owner of your Workforce project configures what map Collector opens.
Esri Education Team
Kylie
Esri Education Team
BrianBulla
Honored Contributor
Hi Kylie,
I have things working now.  Workforce was referencing a map to open that the user didn't have access to.  Thanks for the help!
LeandroLourenço_Bastos
Hi Kylie,
I am trying to save a layer already configured in the collector, however when I capture the point it says "it was not possible to save its feature". This layer is the visualization layer. What can I do?
CraigGillgrass
Leandro,
Is this is a Collector issue or an issue with Workforce?
Are you trying to update the Workforce layer in Collector?
Craig
Hi Craig,
Yes I am trying to save the workforce layer assignments in the collector.
CraigGillgrass
Leandro, can you email the AWorkforce alias?  We can take this discussion to email to troubleshoot it.
Craig
SureI'll be sending itThank you very much!
Craig,
Can you provide the email?
Thanks a lot
