Unable to create project In Workforce
7346
14
12-18-2018 12:24 PM
VincentRobinson
I'm currently unable to create a project in Workforce , the process usually stop at 22% and reads one of the two following messages.
1.Unable to create projects :
Read timed out
2.Unable to create projects :
Access to admin resources are not allowed, Ownership needed for 'AddtoDefinition' with table
 If someone can help me with this I will be forever grateful.
Henry
Hi Craig,
Unfortunately, no luck after creating a second project. Same error, with the Hosted Feature Layers still being created but the Project itself not showing up.
Thank you for the speedy reply, though!
Henry
CraigGillgrass
Henry, are you able to look at the network logs and generate a HAR file in Chrome to try and see the call that is causing the error?
Craig
Henry
Yes, I was able to generate a HAR file for the Network logs.
From the Network logs alone it looks like there's 4 calls that are getting 502 Responses from our server:
3 are addToDefinition calls
1 is updateDefinition
Any recommendations for what to look for in the HAR file for those errors?
Henry
CraigGillgrass
Henry, are you able to share the HAR file?  If you'd prefer, you can email it to the team directly at [email protected]
Craig
Henry
Yes, I have sent the file attached to an email to [email protected]
Thanks!
Henry
