Trouble passing values to Survey123
2587
7
04-12-2019 12:51 PM
MikeOnzay
I'm having trouble passing values to Survey123. With one WF project I could only get the Location value to pass. I created a second WF project and a new survey with 3 text questions. Global ID from WF, Work Order ID from WF, Location from WF. I set up the integration. Only the Global ID will pass the value. Should I be able to pass all 3 values?
Tags (1)
MikeOnzay
I started over today and was passing values without any issues. I was juggling too many things on a late Friday afternoon.
CraigGillgrass
Hi Mike,
You should be able to pass all 3 values (Workforce also support URL schemes for Survey123 that were edited manually in the json)
What release of Workforce and Survey123 are you using and what platform?
thanks,
Craig
MikeOnzay
Workforce v17.0.1
Survey123 v3.3.64
 on iOS v12.1.3
CraigGillgrass
Thanks Mike, I'm not able to reproduce this issue using the same releases/versions.
Can you invite me to this project as a worker and assign me an assignment?  "craig_sp"
MikeOnzay
I'm in an AGOL organization. I think I need to invite you in as a user before I can add you to the project. Unless there is a different way to add you that I'm not aware of
CraigGillgrass
Mike, you can add me to the Workforce project as a Mobile Worker without inviting me first.
Uncheck the box under the user dropdown on the Users tab in Workforce.
Craig
MikeOnzay
by Anonymous User
Not applicable
Mike, would you mind expanding on your solution?
I am trying to update existing workforce assignments with Survey123.
