hide worker locations on workforce mobile app
2624
06-01-2023 05:46 PM
WillyG
Hi
Is there any way we can hide Mobile worker locations with the ArcGIS Workforce app? We have a situation where we have contracted companies working within an organisation, and we don't want them seeing each others locations. Ideally we want this all within one workforce project.  I'm logged in on mobile as a user that has Mobile worker privileges, but not dispatcher privileges and it looks like I can see everyone else's locations.
Kind regards
Willy Gamble
Ethos Environmental
WillyG
Just an update on this. Worker locations can be hidden to applying a filter to the mobile web map. Only way to do it that I can see.
IanGallo
You can make the worker layer not-visible when you publish the worker map from workforce web app. Just unselect the layer in the contents pane. No need to apply a filter.
CandaceHankins
Due to privacy concerns, we did not want our Mobile Workers to be able to see other Workers locations in the Workforce app.
After much testing, I found that Workers were being listed with assignments in the app when clicking on in a blank space of the  map (not on a dot). Attached screenshot shows an example of this.
Turning the visibility off did not prevent this. And since you cannot remove the Workers layer from the Worker map in the Workforce project settings, the only solution is to filter the layer. I chose to filter where Name is blank since I know every user has to have something in the name field.
 Hope this helps someone else!
