Edit existing Survey123 survey from assignment in Workforce
1019
03-15-2022 04:39 PM
MatthewC
I have a set of surveys/locations in Survey123 in the inbox where some of the data is populated in each survey but the remainder needs populated.  I have the feature service associated to the Dispatcher map in Workforce.  I use the existing surveys and their location to assign the work in Workforce but how do I then on the mobile Workforce application get the existing survey to open in Survey123 so that the field user can update the remaining info on the existing survey?
ChrisBerryman
Matthew, have you figured this out yet?  I am also trying to do the same thing.
