Clean up pop-up in Dispatcher Map for assignments
1803
01-05-2021 09:33 AM
WillArellano
Hello,
I just migrated my old Workforce projects from Classic to the new release. I am trying to create a dashboard for upper management using the Dispatcher Map from the workforce project. However, I noticed that the pop-ups for the assignment layer show the globalID for the assignment type and workerID rather than a more user friendly text which I found is hidden in separate tables.
I am thinking I might need to use Arcade to create custom pop-ups to pull the information I need from the related tables using one of the FeatureSet functions, but not sure where to start, and don't have a lot of time to fix this problem. Here is a screenshot of the fields that are currently gobbledygook and need to be more user friendly.
Any help would be appreciated. Thank you!
by Anonymous User
Not applicable
If you're comfortable using Python, we have a script that can generate a joined view that is ideal to use in dashboards since it will allow more filtering and visualization options.
https://github.com/Esri/workforce-scripts/blob/master/readmes/create_joined_view.md
by Anonymous User
Not applicable
WillArellano
Thank you, I will see if I can figure out how to use what you provided. I am just starting to learn Python, and not sure how to use it in AGOL.
WillArellano
I figured out how to run the script, and once I figured out the syntax for passing the arguments to it, everything worked perfectly! Thank you!
ahagopian_coj
Is there any way to do this using Arcade?  I am using the Screening Report widget to generate a customer report and need to add assignment type as the description not the globalid that shows in Assignments.
