Assignment Type Code List
91
2 weeks ago
3CDCOrganizationalAccount
New Contributor III
Is there a way to view all the ID codes for each assignment types in my Workforce Project?
RobertAnderson3
MVP Regular Contributor
If you go to your Content on ArcGIS Online and navigate to the Data tab, you can select the "Assignment Types" table, turn on the GlobalID field and it will show you in there what the ID that shows in the main Assignments table is connected to. Certainly not the cleanest, but it works. You could also add the feature layer to ArcGIS Pro to view the data depending on your needs.
RobertAnderson3
New Contributor III
Thank you for pointing that out
