Workflow Manager for ArcGIS server - does it offer any benefits for web editing?
5617
03-08-2013 12:27 PM
by Anonymous User
Not applicable
At a glance, it would appear WM for AGS offers little in the way of support (management) of edit workflows via a web client (e.g. silverlight/js api consuming feature services).
The only benefits that appear to be offered by WM for AGS is the exposure of the workflow administrative tools & ability to call (invoke) a workflow via a REST endpoint.  Is this the case?  If the latter, in theory it could offer the ability to aid a web client to manage a 'workflow' whereby the webclient is used to perform a particular activity.
About to install WM 4 AGS so will be able to answer myself over next week but would be helpful if anyone is able to answer these queries.
Brad
AllWeatherHeather
I have a similar question. We already use workflow manager extensively for desktop editing and would like to branch out to include web-based editing. I like the idea of using workflow manager workflows to help manage versioning while removing the requirement for more basic users to have access to a full ArcMap installation.
Any new thoughts on this?
TopeBello
Yes, the Launch ArcMap step is just a step that has a lot of logic for manipulating the data layers to repoint the map while opening ArcMap one could do the same in a web application.
If you have a web editing application, I would maybe modify it to accept a parameter in the URL <Your web application URL>?jobVersion=version123.
With this you can use the Open URL step and a token to get the job's version added to the URL when it is executed.
Tope
AllWeatherHeather
Thanks Tope.
Do you know anyone out there today that is using this editing workflow?
TopeBello
Heather,
Yes, but none that I know directly. The trick is to make sure that the web application URL takes the version as a parameter, I did a quick search for URL parsing and found this post. This should be a good start...
Easy URL Parsing With Isomorphic JavaScript
Hope this helps?
Tope
by Anonymous User
Not applicable
As a follow up - our longterm roadmap now includes more integrated web editing experiences
