Task Assistant Manager not saving changes
1350
05-24-2017 03:47 PM
GraemeNewton-Doull
I'm using Task Assistant Manager 10.5 and I'm following the instructions (http://desktop.arcgis.com/en/arcmap/latest/extensions/task-assistant-manager/hiding-the-initializati...) but whenever I click Close, none of the changes I make are saved, apart from "Run as designer". I've tried as a regular user, as a local administrator, and as a domain administrator with no luck.
My investigation has found that apparently this was an issue in version 10.2 (https://community.esri.com/thread/80723) As per the initial user, "Run as designer" is the only setting that saves upon exit.
Windows 7 and 10
ArcGIS Desktop 10.5
Workflow Manager 10.5
DanHopkins
Hi Graeme,
Thank you for bringing this issue to our attention. Others users have reported this issue and the following bug exists in our defect tracking system:
BUG-000102100 - The Configuration Manager for Task Assistant Manager does not hold settings when closed and restarted
Regards,
Dan
