SQL statement to SDE in Flex
604
05-25-2011 11:42 PM
EvgeniaKaradjova
I need to insert data in my Spatial database engine using Flex and sql statements. Can you give me an example of this. There are many SQL examples online using Flex but I can't find SQL to SDE.
Thanks!
TopeBello
Most of the standard SQL commands work with SDE, so this should be pretty similar to the examples that you have seen. Note that there are certain keywords (I don't have a list) that do not work in SDE because they are proprietary to a certain RDBMS.
Tope
