Related properties in ArcMap
2444
11-26-2013 09:26 AM
PeterParker2
We have a Job Type in Workflow Manager that has Related Properties defined (1-M).  When ArcMap is open and the Job Information - Job Properties Window visible, we can only see one of multiple records in the table. Is this a limitation or do we have something incorrectly configured?
Desktop version 10.2.0.3348
Peter
PeterParker2
From an inside source:
So the Job information window in Arcmap will only let you access 1-1 extended properties relationships.  You will have to use WMX desktop under �??linked Properties�?� to see all of them.  The description of the Job information button in ArcMap omits �??linked properties�?� so it looks like a limitation of arcmap integration.
