Limited Views
1347
01-13-2012 02:56 AM
KubilayKüpeli
Hello everybody,
I want to create limit my users to view the map outside the privileged region.
To make it clear,
I have more than hundred regions lets say districts and each has assigned personnel. What i wanted to do is to deny any operation(select, insert, update, delete) in other regions then the user has rights.
Thanks in advance,
Kubilay.
JeremyMirmelstein
Hey Kubilay,
I'd recommend checking out the AOI Edit Extension feature of Workflow Manager in the Help Documentation.
The use of this feature is similar to what you have described in order to prevent/warn users from accidentally doing work outside of their assigned area.
Hope that helps!
Best,
Jeremy
