Cannot edit extended properties
3656
09-06-2012 07:39 AM
AlisonGaiser
I have added an Extended Property table into my Workflow, but unfortunately I can't seem to edit the table. Here is what I did:
  1. Created a table in the WMX repository (WMX_Capital_Works). The table is owned by the WMX user, and I have granted r/w access to all users in the system (for the moment). The table is NOT versioned. The table has a JOB_ID column
  2. In WMX Administrator I added the Extended property table with the JOB_ID as the link field and with a 1:1 relationship
  3. Then in the Job Type, I selected the Extended properties tab and selected the WMX_Capital_Works table.
  4. I toggled off a few of the fields, (JOB_ID, OBJECTID) and set the parameters for the rest of the fields. Some are editable, some are required, I set alias fields and some default values.
  5. Then I created a job of this job type in the Workflow Manager as my user (adm-gaiseral)
  6. When I toggle the extended properties tab, I can see the fields (displaying the ones that I requested to be visible and astericks beside the one defined as required) but I cannot edit the values.
Am I missing something basic?
      Alison
AlisonGaiser
Well I answered my own question - Yes I was missing something basic.
My user did not have the privilege to ManageExtendedProperties.
Once I had granted the user that privilege, I can now edit the properties.
Alison
AlisonGaiser
Alison
