ArcGIS Pro Map Name as parameter using 'Arcade Expression'
1059
09-19-2022 07:29 AM
sirishb
Requirement is to open map in ArcGIS Pro.
We have 20 different maps and to open maps we have to create 20 different flows and pass the map name(hardcoded value).
Instead can we have an option to pass the map name as parameter using 'Arcade Expression' either from 'Extended property' or from 'Userdefined setting'
Sirish
RobertSmith1
Hello @sirishb ,
Thank you for your input!  We do have a feature planned on our roadmap for allowing Arcade expressions for Pro Project Item names, which should allow you to pass your item names dynamically.
Best regards,
Robert
