9.3.1 Service Pack one install
2902
06-03-2010 10:58 AM
ChrisRobinson
I recently upgraded JTX 9.3.1 with service pack one and now I get an error when I try to validate a custom step, such as launching arcmap using an alternative MXD, I get the attached error message.  Even if I try to create a new step using the custom desktop objects, I get that error on all of the JTXDesktopSteps when I try to change the properties on it.   It seems to work fine if I uninstall JTX and reinstall JTX Admin.  Any help or suggestions would be appreciated.  Thanks
MarkMenzel
Have you installed the patch to SP1?
Cheers
Mark
ChrisRobinson
Yes, I installed the patch to SP1.
ChrisRobinson
After thinking about this over the weekend, I realized that the server that JTX is installed on has a partitioned hard drive ( C:\ and E:\ ).  E: is where JTX is installed at.  I tried to watch as the service pack installs and it looked as if it was installing everything to E:\Program Files\JTX  wasn't sure if anyone else had tried this on a partitioned hard drive?
