On-The-Fly area calculation
393
07-03-2024 09:33 PM
BlakeMorrison
I have many polygons in a FS, each with an area attribute listing the area of the feature. The area is either pre-calculated or calculated on creation via an attribute expression in Smart Forms. I display this area attribute as a label on top of each feature. My end users will sometimes be splitting features using the web editor split function, but with the current setup the area attribute displayed in the label will not be re-calculated unless the smart form is used to edit/save attributes.
The only solution I can think of is to calculate the area as an attribute expression within the label, but the accuracy is too variable and unpredictable.
Would it be a reasonable suggestion to request that certain attributes or expressions be re-run/written when geometry has been edited?
CraigGillgrass
Hi @BlakeMorrison this is something we're working on now and we hope to include in Web Editor before the UC in a few weeks.
You're correct, the feature form must be visible for the expressions to be run.  We're looking at how to run expressions when geometry has been edited.
Craig
CraigGillgrass
Craig
BlakeMorrison
Thanks @CraigGillgrass
CraigGillgrass
@BlakeMorrison this should now be possible with an update to Web Editor that we pushed out last night.  Please let me know if this doesn't work for you.
BlakeMorrison
This all works great now. Thank you!
