ArcGIS Web Editor Questions
120
403K
43
| Open | When using the "Edit Vertices" editing option within Web Editor, we need an options to "Confirm" or "Cancel" just lik... by BrettFrahm Frequent Contributor 2 0 | 2 | 0 | |
| Needs Clarification | The Web Editor has an address search capability but it defaults to ESRI's address locator. I would like to have the o... by SteveCole Honored Contributor 0 2 | 0 | 2 | |
| Open | My organization recently updated our Portal version which introduces the Web Editor. Wanted to give that go since I'v... by SteveCole Honored Contributor 0 2 | 0 | 2 | |
| Open | For some time now, there has not been a solution that addresses the use of a traverse in Web Editing outside of a too... by Geographic_Mythos Regular Contributor 8 0 | 8 | 0 | |
| Open | The Web Editor is an ideal tool for lightweight, task‑focused GIS editing, especially for organizations that want to ... by MelanieWawryk Frequent Contributor 6 6 | 6 | 6 | |
| Open | Could you please consider enabling users to natively specify grid size in feet, meters, or their preferred working un... by Miralem_Zeljo Frequent Contributor 2 5 | 2 | 5 | |
| Open | The current Web Editor lacks a fundamental capability: the ability to measure directly on the map. This is a critical... by Miralem_Zeljo Frequent Contributor 5 4 | 5 | 4 | |
| Open | I have a "Review Survey Submission" feature layer and an "External Map Points" feature layer.I want to edit an existi... by Bud Legendary Contributor 0 7 | 0 | 7 | |
| Open | Pop-ups are supported in Web Editor with a few clicks. To view a pop-up, you can Select a featureOpen the Selection p... by Bud Legendary Contributor 4 6 | 4 | 6 | |
| Open | There are mousover tootips for most Instant App - Web Editor buttons. But some tooltips seem to be missing.Idea: Add ... by Bud Legendary Contributor 0 1 | 0 | 1 | |
| Needs Clarification | I am a GIS specialist working with ArcGIS Online and ArcGIS Experience Builder, and I would like to be able to batch ... by AdministratörHolmen Emerging Contributor 0 1 | 0 | 1 | |
| Needs Clarification | Can we have a smart editor widget that is functionally identical?How can we implement the function to intersect a lay... by AurélieFONTEYNE Emerging Contributor 0 2 | 0 | 2 | |
| Under Consideration | I need the ability to be able to maintain attachments from ALL selected features when performing a Merge, not just fr... by MK_MDA Emerging Contributor 0 3 | 0 | 3 | |
| Open | Currently, the web editor adheres to utility network rules, particularly regarding connectivity. When a line is conne... by PierreloupDucroix 0 2 | 0 | 2 | |
| In Product Plan | I'm lacking the possibility to rotate polygons (and polylines) in Web Editor. Editing vertices which Esri support sug... by CarolineLindhe Frequent Contributor 2 1 | 2 | 1 |
Idea Submission Guidelines
