Allow adding geometry to existing features with null shape in web editor
Web Editor has no way to attach geometry to a feature that already exists with a null shape. Editing only supports drawing new features or reshaping ones that already have geometry, and a null-shape record can't be selected on the map since it has no location to click. Right now the only way around it is seeding…
Confirm or Cancel Option for Vertex Editing
When using the "Edit Vertices" editing option within Web Editor, we need an options to "Confirm" or "Cancel" just like the "Reshape" tool. I'm used to the ArcGIS Pro interface that allows this and I cannot count the number of times I've had to just cancel a quick edit I was trying. As the Web Editor is intended as a…
Portal for ArcGIS 11.5 Web Editor Branch Versioning Licensing Patch
With the latest Portal for ArcGIS 11.5 patch, users can now create, edit, and manage branch versions of their data without requiring the Advanced Editing User Type Extension (UTE) for simpler datasets. What does this mean in practice? * Easier access to versioned editing workflows * Lower barriers for teams getting…
Add Map Tools Setting to specify address locator
The Web Editor has an address search capability but it defaults to ESRI's address locator. I would like to have the option to specify a custom address locator which would narrow results and be more accurate using my own organizations address locator.
Add right click pan map functionality while adding features
My organization recently updated our Portal version which introduces the Web Editor. Wanted to give that go since I've been using a small JS 4.x API app to do some basic editing for a particular purpose. One thing I don't like is that if I'm sketching a new linear feature and need to pan the map, I have to use the…
Add Traverse to Web Editor Instant App
For some time now, there has not been a solution that addresses the use of a traverse in Web Editing outside of a tool built into a now defunct Parcel Editor solution in Web App Builder. Even before that, there was a solution called Deed Drafter that did a similar function. Being able to use Traverse in a limited Web…
Move Web Editor access from the Creator user type to the Contributor user type
The Web Editor is an ideal tool for lightweight, task‑focused GIS editing, especially for organizations that want to empower broader teams to make simple updates without requiring full professional GIS software. Our goal is to roll out Web Editor as a streamlined alternative to ArcGIS Pro for users who only need to perform…
Web Editor Grid Sizing
Could you please consider enabling users to natively specify grid size in feet, meters, or their preferred working units? This is a valuable feature, but it currently feels somewhat incomplete compared to the functionality available in ArcGIS Pro.
Measure Tool in Web Editor
The current Web Editor lacks a fundamental capability: the ability to measure directly on the map. This is a critical gap in usability and forces users to rely on workarounds, such as publishing custom measurement layers—something that should not be necessary for basic functionality. Experience Builder already provides…
Edit Your Way with the Web Editor Instant App Template
What’s all the buzz about the new Web Editor template? Its the perfect combination of the configurable Instant Apps interface you know and love and the ArcGIS Web Editor app that streamlines editing on the web. In this article, we’ll walk through examples that show how you can build made-to-order editing apps in ArcGIS…
Web Editor: Field Calculator unavailable in app
So I followed this procedure: Created a hosted layer. Created a webmap with the above layer. Went to the Web Editor interface and use the above, used the above map. The table offers me to Calculate a field for selected records: Then I proceed with the "Create App" function (while in the Web Editor interface). This took me…
Edit two layers at the same time in separate open popups or panes (Instant App - Web Editor)
I have a "Review Survey Submission" feature layer and an "External Map Points" feature layer. I want to edit an existing point from "Review Survey Submission" (edit the Status field) as well as copy its values and paste them into a new "External Map Points" point feature. In other words, I want to edit both layers at the…
Pop-up with fewer clicks
Pop-ups are supported in Web Editor with a few clicks. To view a pop-up, you can * Select a feature * Open the Selection pane * Click the options menu next to the feature name (...) and choose Show pop-up. Pop-ups in Web Editor Template (Instant App) This idea is to access the pop-up window with fewer clicks.
Tooltips in Web Editor Template (Instant App)
There are mousover tootips for most Instant App - Web Editor buttons. But some tooltips seem to be missing. Idea: Add mousover tooltips to all buttons:
Batch editing fails when dependent Arcade expressions are present
I am a GIS specialist working with ArcGIS Online and ArcGIS Experience Builder, and I would like to be able to batch edit fields even when other fields contain Arcade expressions that reference them. Our workflow involves batch editing a field (for example, “Status Åtgärd”). This field is then used in an Arcade expression…
Smart Editor widget to intersect with tolerance distances in Editor widget
Can we have a smart editor widget that is functionally identical? How can we implement the function to intersect a layer? How can we have a choice of tolerance distances and be able to select the values associated with this tolerance in a window?
Maintain Attachments via Merge
I need the ability to be able to maintain attachments from ALL selected features when performing a Merge, not just from the one feature chosen by the tool to maintain attributes from when combining geometries. For agricultural practice inspections, different sections are mapped separately by my field users that I on the…
Being able to disconnect Utility Network features
Currently, the web editor adheres to utility network rules, particularly regarding connectivity. When a line is connected to a point, moving the end of the line also moves the connected point. However, it would be beneficial to be able to disconnect lines from points, as is the case in ArcGIS Pro :
Measuring widget for Instant app Web Editor
Can you add a Measuring Tool option to Instant Apps (Web Editor, etc)?
Identify widget for Instant App Web Edtor
Identify widget missing from the Instant app Web Editor (Beta). Can you add this option to the Instant App?
ArcGIS 11.3 Web Editor Install
I have recently install arcgis web editor app on our portal system. The installation was successful but the app isn't showing up. User is a GIS Pro Advance with admin privs and we are license to use this feature. I looked in C:\Program Files\ArcGIS\Portal\apps and there isn't any webeditor folder like the documentation…
Paste Special not pasting an integer into an integer field
I am attempting to use the Web Editor in ArcGIS Online with a task-enabled layer. I'm hoping I can use the Web Editor to speed up task creation using Copy + Paste Special but I'm running into an issue with getting a value between the source and destination layer. The source layer has a "Small Integer" field (this layer is…
Ability to rotate polygons and polylines in Web Editor
I'm lacking the possibility to rotate polygons (and polylines) in Web Editor. Editing vertices which Esri support suggested does not easily solve this need. Editing vertices makes it much more difficult to preserve the shape of a polygon. Please make a rotation tool available!
Ability to create new shapes using a buffer
This suggestion is similar but different to the option to create circles here: https://community.esri.com/t5/arcgis-web-editor-ideas/capability-to-draw-circle/idc-p/1498389 Using Pro, the Buffer editing tool allows a user to create a buffered version of an existing feature. This functionality appears to be missing from…
Remove the delete button from Default version settings
I hope this delete button does nothing, but it is scary to me to have a delete action associated with the Default version. Please remove the delete button from the Default version settings menu.
