Wish to add MapImageLayers to WAB application through LocalLayerWidget
3440
07-20-2015 11:27 PM
HumzaAkhtar
Can anyone give me some pointers on how to go about doing this ?   There will be some changes to be done in the LocalLayerWidget code I believe.
HumzaAkhtar
Figured it out,,
Add the json of the layer to config_Local Layer Widget.json :
       "type": "Mapimage",
        "name": "Animation Layer",
        "href": "http://www.aoaophoto.com/video-to-gif-converter/imgs/sample-iceage4.gif",
        "extent": { "xmin": -79.933333, "ymin": 32.783333, "xmax": -80.933333, "ymax": 33.783333, "spatialReference":{"wkid":4326}},
        "opacity": 1,
        "visible": false
Then Add the following code to the Widget.js file  (in the startup function)
if(layer.type.toUpperCase() === 'MAPIMAGE'){
            var mil = new MapImage({
            'extent': layer.extent,
            'href': layer.href
            lOptions.extent = layer.extent;
            lLayer =new MapImageLayer(lOptions);
            lLayer.addImage(mil);
            lLayer.on("load", function() {
             evt.layer.name = lOptions.id;
            this._viewerMap.addLayer(lLayer);
HumzaAkhtar
Figured it out,,
       "type": "Mapimage",
        "opacity": 1,
        "visible": false
            'href': layer.href
