Webapp Builder Layer List Widget
21399
45
08-18-2015 04:44 PM
JayClark
My table of contents has 4 group layers (each group can have multiple layers).  When the user clicks on "Critical Area" group, I also want the event to check on and draw the "Percent Slope" group.  I'm not really interested in answering questions about why I would want to do this way, because it is kind of nutty, but rather, how to do this in the javascript code, so that I get better at tinkering with the widgets.  I'm able to write to the console if a user checks on "Critical Areas" but not at all sure how to have the code check on and draw the "Percent Slope" group:
From the "LayerListView.js" in the Layer list widger for webappbuilder:
   _onCkSelectNodeClick: function(layerInfo, ckSelect, evt) {
      if (ckSelect.checked) {
        layerInfo.setTopLayerVisible(true);
//  test how to find layer name
        if (layerInfo.title === 'Critical Areas')
              console.log(layerInfo.title);
//  I want this to check on and draw another group in the layer list--Any ideas?
      } else {
        layerInfo.setTopLayerVisible(false);
      evt.stopPropagation();
Mehretab
You mean to change from one theme (group to another group) like in the above mentioned application? example From Surface Water Bodies to Protected area and so on?
You are right @ Robert Scheitlin, GISP  I am not switching between web maps, its only loading another map layers.This was accomplished via a widget created for such purpose as there is no way  to group service into categories as of today in arcgis api for javascript 3.xx, pardon me if there is possibility to group layers.
ikbelkachbouri
yeah i mean how to change from one group to another . is it a group of layer or webmaps ? and if it is a group of layers how to do so ?
ikbelkachbouri
How to group layers please ?
ikbelkachbouri
Can you explain to me more how to group layers and how to get the widget to toggle between groups of layers ?
RobertScheitlin__GISP
So are you changing the web map in that widget?
Mehretab
No I am clearing the previous maps and add the new group using the buttons.
ikbelkachbouri
Mehretab
I think It would be easy for me to share the widget than to explain it here . Give me some time though?
ikbelkachbouri
Ok Mr Mehretab T.Sium . Thank you so much . really thank you so much .
AmalHorchi
Hi Mehretab ,
What about the widget  to toggle betwenn group of layers ?
