Webapp Builder Layer List Widget
21276
45
08-18-2015 04:44 PM
JayClark
My table of contents has 4 group layers (each group can have multiple layers).  When the user clicks on "Critical Area" group, I also want the event to check on and draw the "Percent Slope" group.  I'm not really interested in answering questions about why I would want to do this way, because it is kind of nutty, but rather, how to do this in the javascript code, so that I get better at tinkering with the widgets.  I'm able to write to the console if a user checks on "Critical Areas" but not at all sure how to have the code check on and draw the "Percent Slope" group:
From the "LayerListView.js" in the Layer list widger for webappbuilder:
   _onCkSelectNodeClick: function(layerInfo, ckSelect, evt) {
      if (ckSelect.checked) {
        layerInfo.setTopLayerVisible(true);
//  test how to find layer name
        if (layerInfo.title === 'Critical Areas')
              console.log(layerInfo.title);
//  I want this to check on and draw another group in the layer list--Any ideas?
      } else {
        layerInfo.setTopLayerVisible(false);
      evt.stopPropagation();
ikbelkachbouri
Hi , how can you toggle between multiple maps . thanks
Mehretab
This piece of code toggles between 3 services if you have 4 or more put the services to hidden or invisible  on the list of
if (layerInfo.title === 'the title of your map1')  //you can find it from the layer list widget (title) {
           //  how to find layer id
              //console.log(layerInfo.id);
this.layerListWidget.operLayerInfos.getLayerInfoById('map Id_2').setTopLayerVisible(false);
this.layerListWidget.operLayerInfos.getLayerInfoById('map Id_3').setTopLayerVisible(false);
//THE FOUR LAYER WILL BE PUT HERE AND THE SAME IS TRUE IN THE OTHER IF STATEMENTS‍‍‍‍
this.layerListWidget.operLayerInfos.getLayerInfoById('map Id_4').setTopLayerVisible(false);
/THE FIVES LAYER WILL BE PUT HERE AND THE SAME IS TRUE IN THE OTHER IF STATEMENTS‍‍‍‍
this.layerListWidget.operLayerInfos.getLayerInfoById('map Id_5').setTopLayerVisible(false);
//AND SO ON AS MANY LAYERS AS YOUR APP GOT‍‍‍‍‍‍‍‍
Basically the code is making everyone else invisible but  but the map with the specified title, in our case
ikbelkachbouri
I just have one map .
ikbelkachbouri
Hi Mehretab ,
Map Démographie : 1a02ace3ed3547169d88deb4dcb8ce97
Map Infrastructure : 389912da2d0b4123b4270e2ba0d7a7e0
// Copyright © 2014 - 2017 Esri. All Rights Reserved.
// Licensed under the Apache License Version 2.0 (the "License");
// you may not use this file except in compliance with the License.
// You may obtain a copy of the License at
// http://www.apache.org/licenses/LICENSE-2.0
// Unless required by applicable law or agreed to in writing, software
// distributed under the License is distributed on an "AS IS" BASIS,
// WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
// See the License for the specific language governing permissions and
// limitations under the License.
define([
'dijit/_WidgetBase',
'dojo/_base/declare',
'dojo/_base/lang',
'dojo/_base/array',
'dojo/dom-construct',
'dojo/on',
'dojo/query',
'jimu/dijit/CheckBox',
'jimu/dijit/DropMenu',
'./PopupMenu',
'dijit/_TemplatedMixin',
'dojo/text!./LayerListView.html',
'dojo/dom-class',
'dojo/dom-style',
'./NlsStrings'
], function(_WidgetBase, declare, lang, array, domConstruct, on, query,
CheckBox, DropMenu, PopupMenu, _TemplatedMixin, template,
domClass, domStyle, NlsStrings) {
return declare([_WidgetBase, _TemplatedMixin], {
templateString: template,
_currentSelectedLayerRowNode: null,
operationsDropMenu: null,
_layerNodeHandles: null,
// _layerDomNodeStorage = {
// layerInfoObjectId: {// layerDomNode
// layerTrNode: domNode,
// layerContentTrNode: domeNode,
// layerNodeEventHandles: []
// layerNodeReferredDijits: []
_layerDomNodeStorage: null,
postMixInProperties: function() {
this.inherited(arguments);
this.nls = NlsStrings.value;
this._layerDomNodeStorage = {};
postCreate: function() {
this.refresh();
this._initOperations();
refresh: function() {
this._removeLayerNodes();
array.forEach(this.operLayerInfos.getLayerInfoArray(), function(layerInfo) {
this.drawListNode(layerInfo, 0, this.layerListTable);
}, this);
array.forEach(this.operLayerInfos.getTableInfoArray(), function(layerInfo) {
this.drawListNode(layerInfo, 0, this.tableListTable);
}, this);
drawListNode: function(layerInfo, level, toTableNode, position) {
var nodeAndSubNode, showLegendDiv;
if(this.isLayerHiddenInWidget(layerInfo)) {
return;
nodeAndSubNode = this._layerDomNodeStorage[layerInfo.getObjectId()];
if((layerInfo.isRootLayer() || layerInfo.isTable) && nodeAndSubNode) {
domConstruct.place(nodeAndSubNode.layerTrNode, toTableNode, position);
domConstruct.place(nodeAndSubNode.layerContentTrNode, toTableNode, position);
} else if (layerInfo.newSubLayers.length === 0) {
//addLayerNode
nodeAndSubNode = this.addLayerNode(layerInfo, level, toTableNode, position);
//add legend node
if (this.config.showLegend) {
this.addLegendNode(layerInfo, level, nodeAndSubNode.subNode);
} else {
showLegendDiv = query(".showLegend-div", nodeAndSubNode.layerTrNode)[0];
if(showLegendDiv) {
domClass.add(showLegendDiv, 'hidden');
} else {
//addLayerNode
array.forEach(layerInfo.newSubLayers, lang.hitch(this, function(level, subLayerInfo) {
this.drawListNode(subLayerInfo, level + 1, nodeAndSubNode.subNode);
}, level));
addLayerNode: function(layerInfo, level, toTableNode, position) {
var layerTrNode, layerTdNode, ckSelectDiv, ckSelect, imageNoLegendDiv, handle,
imageNoLegendNode, popupMenuNode, i, imageShowLegendDiv, divLabel;
var rootLayerInfo = layerInfo.getRootLayerInfo();
// if(!this._layerNodeHandles[rootLayerInfo.id]) {
// this._layerNodeHandles[rootLayerInfo.id] = [];
// init _layerDomNodeStorage for rootLayerInfo.
if(layerInfo.isRootLayer() || layerInfo.isTable) {
this._layerDomNodeStorage[layerInfo.getObjectId()] = {
layerTrNode: null,
layerContentTrNode: null,
layerNodeEventHandles: [],
var layerTrNodeClass = "layer-tr-node-" + layerInfo.id;
layerTrNode = domConstruct.create('tr', {
'class': 'jimu-widget-row layer-row ' +
( /*visible*/ false ? 'jimu-widget-row-selected ' : ' ') + layerTrNodeClass,
'layerTrNodeId': layerInfo.id
domConstruct.place(layerTrNode, toTableNode, position);
layerTdNode = domConstruct.create('td', {
'class': 'col col1'
}, layerTrNode);
for (i = 0; i < level; i++) {
domConstruct.create('div', {
'class': 'begin-blank-div jimu-float-leading',
'innerHTML': ''
}, layerTdNode);
imageShowLegendDiv = domConstruct.create('div', {
'class': 'showLegend-div jimu-float-leading',
'imageShowLegendDivId': layerInfo.id
}, layerTdNode);
ckSelectDiv = domConstruct.create('div', {
'class': 'div-select jimu-float-leading'
}, layerTdNode);
ckSelect = new CheckBox({
checked: layerInfo.isVisible(), //layerInfo.visible
'class': "visible-checkbox-" + layerInfo.id
domConstruct.place(ckSelect.domNode, ckSelectDiv);
imageNoLegendDiv = domConstruct.create('div', {
'class': 'noLegend-div jimu-float-leading'
}, layerTdNode);
var imageName;
if (layerInfo.isTable) {
imageName = 'images/table.png';
} else {
imageName = 'images/noLegend.png';
imageNoLegendNode = domConstruct.create('img', {
'class': 'noLegend-image',
'src': this.layerListWidget.folderUrl + imageName,
'alt': 'l'
}, imageNoLegendDiv);
if (layerInfo.isTiled || layerInfo.isTable) {
domStyle.set(imageShowLegendDiv, 'display', 'none');
domStyle.set(ckSelectDiv, 'display', 'none');
domStyle.set(imageNoLegendDiv, 'display', 'block');
// set tdNode width
domStyle.set(layerTdNode, 'width', level * 12 + 40 + 'px');
var layerTitleTdNode = domConstruct.create('td', {
'class': 'col col2'
}, layerTrNode);
var grayedTitleClass = '';
try {
if (!layerInfo.isInScale()) {
grayedTitleClass = 'grayed-title';
} catch (err) {
console.warn(err.message);
var layerTitleDivIdClass = 'layer-title-div-' + layerInfo.id;
divLabel = domConstruct.create('div', {
'innerHTML': layerInfo.title,
'class':layerTitleDivIdClass + ' div-content jimu-float-leading ' + grayedTitleClass
}, layerTitleTdNode);
//domStyle.set(divLabel, 'width', 263 - level*13 + 'px');
'class': 'col col3'
}, layerTrNode);
var popupMenuDisplayStyle = this.hasContentMenu() ? "display: block" : "display: none";
// add popupMenu
popupMenuNode = domConstruct.create('div', {
'class': 'layers-list-popupMenu-div',
'style': popupMenuDisplayStyle
}, layerTdNode);
var handle = on(popupMenuNode,
'click',
lang.hitch(this, function() {
var popupMenu = new PopupMenu({
//items: layerInfo.popupMenuInfo.menuItems,
_layerInfo: layerInfo,
box: this.layerListWidget.domNode.parentNode,
popupMenuNode: popupMenuNode,
layerListWidget: this.layerListWidget,
_config: this.config
}).placeAt(popupMenuNode);
this.own(on(popupMenu,
'onMenuClick',
lang.hitch(this, this._onPopupMenuItemClick, layerInfo, popupMenu)));
handle.remove();
'onMenuClick',
//add a tr node to toTableNode.
var layerContentTrNode = domConstruct.create('tr', {
'class': '',
'layerContentTrNodeId': layerInfo.id
domConstruct.place(layerContentTrNode, toTableNode, position);
var tdNode = domConstruct.create('td', {
'class': '',
'colspan': '3'
}, layerContentTrNode);
var tableNode = domConstruct.create('table', {
'class': 'layer-sub-node',
'subNodeId': layerInfo.id
}, tdNode);
//bind event
handle = this.own(on(layerTitleTdNode,
'click',
lang.hitch(this,
this._onRowTrClick,
layerInfo,
imageShowLegendDiv,
layerTrNode,
tableNode)));
//this._layerNodeHandles[rootLayerInfo.id].push(handle[0]);
this._storeLayerNodeEventHandle(rootLayerInfo, handle[0]);
handle = this.own(on(imageShowLegendDiv,
'click',
lang.hitch(this,
this._onRowTrClick,
layerInfo,
imageShowLegendDiv,
layerTrNode,
tableNode)));
handle = this.own(on(ckSelect.domNode, 'click', lang.hitch(this,
this._onCkSelectNodeClick,
layerInfo,
ckSelect)));
handle = this.own(on(popupMenuNode, 'click', lang.hitch(this,
this._onPopupMenuClick,
layerInfo,
popupMenuNode,
layerTrNode)));
this._layerDomNodeStorage[layerInfo.getObjectId()].layerTrNode = layerTrNode;
this._layerDomNodeStorage[layerInfo.getObjectId()].layerContentTrNode = layerContentTrNode;
return {
layerTrNode: layerTrNode,
subNode: tableNode
hasContentMenu: function() {
var hasContentMenu = false;
var item;
if(this.config.contextMenu) {
for (item in this.config.contextMenu) {
if(this.config.contextMenu.hasOwnProperty(item) &&
(typeof this.config.contextMenu[item] !== 'function')) {
hasContentMenu = hasContentMenu || this.config.contextMenu[item];
} else {
hasContentMenu = true;
return hasContentMenu;
addLegendNode: function(layerInfo, level, toTableNode) {
//var legendsDiv;
var legendTrNode = domConstruct.create('tr', {
'class': 'legend-node-tr'
}, toTableNode),
legendTdNode;
legendTdNode = domConstruct.create('td', {
'class': 'legend-node-td'
}, legendTrNode);
try {
var legendsNode = layerInfo.createLegendsNode();
//layerInfo.legendsNode = legendsNode;
//domStyle.set(legendsNode, 'marginLeft', (level+1)*12 + 'px');
domStyle.set(legendsNode, 'font-size', (level + 1) * 12 + 'px');
domConstruct.place(legendsNode, legendTdNode);
} catch (err) {
console.error(err);
redrawLegends: function(layerInfo) {
var legendsNode = query("div[legendsDivId='" + layerInfo.id + "']", this.layerListTable)[0];
if(legendsNode) {
if(legendsNode._legendDijit && legendsNode._legendDijit.destroy) {
legendsNode._legendDijit.destroy();
layerInfo.drawLegends(legendsNode, this.layerListWidget.appConfig.portalUrl);
// destroyLayerTrNode: function(layerInfo) {
// var removedLayerNode = query("[class~='layer-tr-node-" + layerInfo.id + "']", this.domNode)[0];
// var removedLayerContentNode = query("[layercontenttrnodeid='" + layerInfo.id + "']", this.domNode)[0];
// if(removedLayerNode) {
// var rootLayerInfo = layerInfo.getRootLayerInfo();
// array.forEach(this._layerNodeHandles[rootLayerInfo.id], function(handle) {
// handle.remove();
// }, this);
// delete this._layerNodeHandles[rootLayerInfo.id];
// domConstruct.destroy(removedLayerNode);
// if(removedLayerContentNode) {
// domConstruct.destroy(removedLayerContentNode);
* methods for refresh layerListView
_storeLayerNodeEventHandle: function(rootLayerInfo, handle) {
var rootLayerStorage = this._layerDomNodeStorage[rootLayerInfo.getObjectId()];
if(rootLayerStorage) {
rootLayerStorage.layerNodeEventHandles.push(handle);
_storeLayerNodeDijit: function(rootLayerInfo, dijit) {
rootLayerStorage.layerNodeReferredDijits.push(dijit);
_clearLayerDomNodeStorage:function() {
//jshint unused:false
var layerInfoArray = this.operLayerInfos.getLayerInfoArray();
var tableInfoArray = this.operLayerInfos.getTableInfoArray();
var layerAndTableInfoArray = layerInfoArray.concat(tableInfoArray);
var findElem;
for(var elem in this._layerDomNodeStorage) {
if(this._layerDomNodeStorage.hasOwnProperty(elem) &&
(typeof this._layerDomNodeStorage[elem] !== 'function')) {
/* jshint loopfunc: true */
findElem = array.some(layerAndTableInfoArray, function(layerInfo) {
if(layerInfo.getObjectId().toString() === elem) {
return true;
}, this);
if(!findElem) {
//release layer node.
array.forEach(this._layerDomNodeStorage[elem].layerNodeEventHandles, function(handle) {
handle.remove();
}, this);
array.forEach(this._layerDomNodeStorage[elem].layerNodeReferredDijits, function(dijit) {
dijit.destroy();
}, this);
domConstruct.destroy(this._layerDomNodeStorage[elem].layerTrNode);
domConstruct.destroy(this._layerDomNodeStorage[elem].layerContentTrNode);
delete this._layerDomNodeStorage[elem];
_removeLayerNodes: function() {
var nodeAndSubNode, parentNode;
this._clearLayerDomNodeStorage();
nodeAndSubNode = this._layerDomNodeStorage[elem];
if(nodeAndSubNode.parentNode && nodeAndSubNode.layerTrNode) {
parentNode = nodeAndSubNode.layerTrNode.parentNode;
if(parentNode) {
parentNode.removeChild(nodeAndSubNode.layerTrNode);
parentNode = nodeAndSubNode.layerContentTrNode.parentNode;
if(parentNode) {
parentNode.removeChild(nodeAndSubNode.layerContentTrNode);
// this.inherited(arguments);
* methods for control layerListView
// return current state:
// true: fold,
// false: unfold
_foldSwitch: function(layerInfo, imageShowLegendDiv, subNode) {
/*jshint unused: false*/
var state;
if (domStyle.get(subNode, 'display') === 'none') {
state = this._foldOrUnfoldLayer(layerInfo, false, imageShowLegendDiv, subNode);
} else {
state = this._foldOrUnfoldLayer(layerInfo, true, imageShowLegendDiv, subNode);
return state;
_foldOrUnfoldLayer: function(layerInfo, isFold, imageShowLegendDivParam, subNodeParam) {
var imageShowLegendDiv =
imageShowLegendDiv ?
imageShowLegendDivParam :
query("div[imageShowLegendDivId='" + layerInfo.id + "']", this.layerListTable)[0];
var subNode =
subNode ?
subNodeParam :
query("table[subNodeId='" + layerInfo.id + "']", this.layerListTable)[0];
var state = null;
if(imageShowLegendDiv && subNode) {
if (isFold) {
//fold
domStyle.set(subNode, 'display', 'none');
domClass.remove(imageShowLegendDiv, 'unfold');
state = true;
} else {
//unfold
domStyle.set(subNode, 'display', 'table');
domClass.add(imageShowLegendDiv, 'unfold');
state = false;
if (layerInfo.isLeaf()) {
var legendsNode = query(".legends-div", subNode)[0];
var loadingImg = query(".legends-loading-img", legendsNode)[0];
if (legendsNode && loadingImg) {
return state;
_foldOrUnfoldLayers: function(layerInfos, isFold) {
array.forEach(layerInfos, function(layerInfo) {
this._foldOrUnfoldLayer(layerInfo, isFold);
}, this);
if(evt.ctrlKey || evt.metaKey) {
if(layerInfo.isRootLayer()) {
this.turnAllRootLayers(ckSelect.checked);
} else {
this.turnAllSameLevelLayers(layerInfo, ckSelect.checked);
} else {
this.layerListWidget._denyLayerInfosIsVisibleChangedResponseOneTime = true;
layerInfo.setTopLayerVisible(ckSelect.checked);
_onPopupMenuClick: function(layerInfo, popupMenuNode, layerTrNode, evt) {
var popupMenu = popupMenuNode.popupMenu;
if(!popupMenu) {
popupMenuNode.popupMenu = popupMenu;
this._storeLayerNodeDijit(rootLayerInfo, popupMenu);
var handle = this.own(on(popupMenu,
'onMenuClick',
this._changeSelectedLayerRow(layerTrNode);
if (popupMenu && popupMenu.state === 'opened') {
popupMenu.closeDropMenu();
} else {
this._hideCurrentPopupMenu();
if (popupMenu) {
this.currentPopupMenu = popupMenu;
popupMenu.openDropMenu();
//hidden operation mene if that is opened.
if (this.operationsDropMenu && this.operationsDropMenu.state === 'opened') {
this.operationsDropMenu.closeDropMenu();
_hideCurrentPopupMenu: function() {
if (this.currentPopupMenu && this.currentPopupMenu.state === 'opened') {
this.currentPopupMenu.closeDropMenu();
_onLayerListWidgetPaneClick: function() {
if (this.operationsDropMenu) {
_onRowTrClick: function(layerInfo, imageShowLegendDiv, layerTrNode, subNode, evt) {
var fold = this._foldSwitch(layerInfo, imageShowLegendDiv, subNode);
this.foldOrUnfoldAllRootLayers(fold);
} else {
this.foldOrUnfoldSameLevelLayers(layerInfo, fold);
_changeSelectedLayerRow: function(layerTrNode) {
if (this._currentSelectedLayerRowNode && this._currentSelectedLayerRowNode === layerTrNode) {
return;
if (this._currentSelectedLayerRowNode) {
domClass.remove(this._currentSelectedLayerRowNode, 'jimu-widget-row-selected');
domClass.add(layerTrNode, 'jimu-widget-row-selected');
this._currentSelectedLayerRowNode = layerTrNode;
_onPopupMenuItemClick: function(layerInfo, popupMenu, item, data) {
var evt = {
itemKey: item.key,
extraData: data,
layerListView: this
result;
// window.jimuNls.layerInfosMenu.itemTransparency NlsStrings.value.itemTransparency
if (item.key === 'transparency') {
if (domStyle.get(popupMenu.transparencyDiv, 'display') === 'none') {
popupMenu.showTransNode(layerInfo.getOpacity());
} else {
popupMenu.hideTransNode();
} else {
result = popupMenu.popupMenuInfo.onPopupMenuClick(evt);
if (result.closeMenu) {
* methods for control moveUp/moveDown.
// befor exchange: id1 -> id2
// after exchanged: id2 -> id1
_exchangeLayerTrNode: function(layerInfo1, layerInfo2) {
var layer1TrNode = query("tr[layerTrNodeId='" + layerInfo1.id + "']", this.layerListTable)[0];
//var layer1ContentTrNode = query("tr[layerContentTrNodeId='" + layerInfo1.id + "']",
// this.layerListTable)[0];
var layer2TrNode = query("tr[layerTrNodeId='" + layerInfo2.id + "']", this.layerListTable)[0];
var layer2ContentTrNode = query("tr[layerContentTrNodeId='" + layerInfo2.id + "']",
if(layer1TrNode && layer2TrNode && layer2ContentTrNode) {
// change layerTr
this.layerListTable.removeChild(layer2TrNode);
this.layerListTable.insertBefore(layer2TrNode, layer1TrNode);
// change LayerContentTr
this.layerListTable.removeChild(layer2ContentTrNode);
this.layerListTable.insertBefore(layer2ContentTrNode, layer1TrNode);
_getMovedSteps: function(layerInfo, upOrDown) {
// summary:
// according to hidden layers to get moved steps.
var steps = 1;
var layerInfoIndex;
array.forEach(layerInfoArray, function(currentLayerInfo, index) {
if(layerInfo.id === currentLayerInfo.id) {
layerInfoIndex = index;
}, this);
if(upOrDown === "moveup") {
while(!layerInfoArray[layerInfoIndex].isFirst) {
layerInfoIndex--;
if(this.isLayerHiddenInWidget(layerInfoArray[layerInfoIndex]) &&
steps++;
} else {
break;
} else {
while(!layerInfoArray[layerInfoIndex].isLast) {
layerInfoIndex++;
steps++;
} else {
break;
return steps;
moveUpLayer: function(layerInfo) {
// summary:
// move up layer in layer list.
// description:
// call the moveUpLayer method of LayerInfos to change the layer order in map,
// and update the data in LayerInfos
// then, change layerNodeTr and layerContentTr domNode
var steps = this._getMovedSteps(layerInfo, 'moveup');
this.layerListWidget._denyLayerInfosReorderResponseOneTime = true;
var beChangedLayerInfo = this.operLayerInfos.moveUpLayer(layerInfo, steps);
if (beChangedLayerInfo) {
this._exchangeLayerTrNode(beChangedLayerInfo, layerInfo);
moveDownLayer: function(layerInfo) {
// summary:
// move down layer in layer list.
// description:
// call the moveDownLayer method of LayerInfos to change the layer order in map,
var steps = this._getMovedSteps(layerInfo, 'movedown');
var beChangedLayerInfo = this.operLayerInfos.moveDownLayer(layerInfo, steps);
this._exchangeLayerTrNode(layerInfo, beChangedLayerInfo);
isLayerHiddenInWidget: function(layerInfo) {
var isHidden = false;
var currentLayerInfo = layerInfo;
if(layerInfo &&
this.config.layerOptions &&
this.config.layerOptions[layerInfo.id] !== undefined) {
while(currentLayerInfo) {
isHidden = isHidden || !this.config.layerOptions[currentLayerInfo.id].display;
if(isHidden) {
break;
currentLayerInfo = currentLayerInfo.parentLayerInfo;
} else {
// if config has not been configured, default value is 'true'.
// if config has been configured, but new layer of webmap is ont in config file,
// default value is 'true'.
isHidden = false;
return isHidden;
isFirstDisplayedLayerInfo: function(layerInfo) {
var isFirst;
var steps;
var layerInfoIndex;
var layerInfoArray;
if(layerInfo.isFirst || !layerInfo.isRootLayer()) {
isFirst = true;
} else {
steps = this._getMovedSteps(layerInfo, "moveup");
layerInfoIndex = this.operLayerInfos._getTopLayerInfoIndexById(layerInfo.id);
if(this.isLayerHiddenInWidget(layerInfoArray[layerInfoIndex - steps])) {
isFirst = true;
} else {
isFirst = false;
return isFirst;
isLastDisplayedLayerInfo: function(layerInfo) {
var isLast;
var steps;
var layerInfoIndex;
var layerInfoArray;
if(layerInfo.isLast || !layerInfo.isRootLayer()) {
isLast = true;
} else {
steps = this._getMovedSteps(layerInfo, "movedown");
if(this.isLayerHiddenInWidget(layerInfoArray[layerInfoIndex + steps])) {
isLast = true;
} else {
isLast = false;
return isLast;
* methods for control operation.
_initOperations: function() {
this.operationsDropMenu = new DropMenu({
items:[{
key: "turnAllLayersOn",
label: this.nls.turnAllLayersOn
key: "turnAllLayersOff",
label: this.nls.turnAllLayersOff
key: "separator"
key: "expandAllLayers",
label: this.nls.expandAllLayers
key: "collapseAlllayers",
label: this.nls.collapseAlllayers
}).placeAt(this.layerListOperations);
var operationIconBtnNode = query('div.jimu-dropmenu > div:first-child',
this.layerListOperations)[0];
if(operationIconBtnNode) {
domClass.remove(operationIconBtnNode, ['jimu-icon-btn', 'popup-menu-button']);
domClass.add(operationIconBtnNode, ['feature-action', 'icon-operation']);
if(this.operationsDropMenu.btnNode) {
this.own(on(this.operationsDropMenu.btnNode,
'click',
lang.hitch(this, this._onLayerListOperationsClick)));
this.own(on(this.operationsDropMenu ,
'onMenuClick',
lang.hitch(this, this._onOperationsMenuItemClick)));
_onLayerListOperationsClick: function() {
_onOperationsMenuItemClick: function(item) {
switch (item.key) {
case 'turnAllLayersOn':
this.turnAllRootLayers(true);
return;
case 'turnAllLayersOff':
this.turnAllRootLayers(false);
return;
case 'expandAllLayers':
this.foldOrUnfoldAllRootLayers(false);
return;
case 'collapseAlllayers':
this.foldOrUnfoldAllRootLayers(true);
return;
default:
return;
turnAllRootLayers: function(isOnOrOff) {
array.forEach(layerInfoArray, function(layerInfo) {
if (!this.isLayerHiddenInWidget(layerInfo)) {
layerInfo.setTopLayerVisible(isOnOrOff);
}, this);
turnAllSameLevelLayers: function(layerInfo, isOnOrOff) {
var layerOptions = {};
rootLayerInfo.traversal(lang.hitch(this, function(subLayerInfo) {
if(subLayerInfo.parentLayerInfo &&
subLayerInfo.parentLayerInfo.id === layerInfo.parentLayerInfo.id &&
!this.isLayerHiddenInWidget(subLayerInfo)) {
layerOptions[subLayerInfo.id] = {visible: isOnOrOff};
} else {
layerOptions[subLayerInfo.id] = {visible: subLayerInfo.isVisible()};
rootLayerInfo.resetLayerObjectVisibility(layerOptions);
foldOrUnfoldAllRootLayers: function(isFold) {
var layerInfoArray = array.filter(this.operLayerInfos.getLayerInfoArray(),
return !this.isLayerHiddenInWidget(layerInfo);
}, this);
this._foldOrUnfoldLayers(layerInfoArray, isFold);
foldOrUnfoldSameLevelLayers: function(layerInfo, isFold) {
var layerInfoArray;
if(layerInfo.parentLayerInfo) {
layerInfoArray = array.filter(layerInfo.parentLayerInfo.getSubLayers(),
}, this);
Mehretab
So basically you are looking to toggle between sublayres in your  Web Map? If so Robert Scheitlin, GISP got already a solution to toggle between sublayers  in this thread
RobertScheitlin__GISP
Mehretab,
   Thanks for linking that thread I completely forgot about that one.
ikbelkachbouri
I don't have sublayers .
Mehretab
Well this is the same scenario like in my application I already provided the piece of code that does the trick.
in your  case the map title will for example,  'Population Totale' in the first if statement and insert the ids of the other services you want to hide:
this.layerListWidget.operLayerInfos.getLayerInfoById('map Id you want to hide').setTopLayerVisible(false);
If you do not know how to get the map ids just uncomment the  //console.log(layerInfo.id) or you can right click on your service and see the id of the particular service in you console (see the image)
        if (layerInfo.title === 'Population Totale')  {
this.layerListWidget.operLayerInfos.getLayerInfoById('Nombre de naissances Id').setTopLayerVisible(false);
this.layerListWidget.operLayerInfos.getLayerInfoById('Solde migratoire Id').setTopLayerVisible(false);
this.layerListWidget.operLayerInfos.getLayerInfoById('Nobre de mariages Id ').setTopLayerVisible(false);
this.layerListWidget.operLayerInfos.getLayerInfoById('Nombre de divorces Id').setTopLayerVisible(false);
this.layerListWidget.operLayerInfos.getLayerInfoById('Nombre de deces Id').setTopLayerVisible(false);
this.layerListWidget.operLayerInfos.getLayerInfoById('Taux Brut de Natalite Id ').setTopLayerVisible(false);
this.layerListWidget.operLayerInfos.getLayerInfoById('Taux Global  de Fecondite Id').setTopLayerVisible(false);
   if (layerInfo.title === 'Nombre de naissances')   {
this.layerListWidget.operLayerInfos.getLayerInfoById('Population Totale Id').setTopLayerVisible(false);
if (layerInfo.title === 'Solde migratoire Id')  {
//THE SAME IS TRUE HERE....PUT THE Id's OF MAP YOU WANT TO HIDE
      } else {
  Put this code in the LayerListVies.js's _onCkSelectNodeClick function. Probably you will need to delete the existing code and replace it with this code.
This  should work for you if you use the appropriate Id and map title.
ikbelkachbouri
I appreciate your work in IKSR Map Application how to toggle betwenn maps and layers ? Where is the code source ?
Mehretab
The code is already there and try it out and let me know
