Webapp Builder Layer List Widget
21357
45
08-18-2015 04:44 PM
JayClark
My table of contents has 4 group layers (each group can have multiple layers).  When the user clicks on "Critical Area" group, I also want the event to check on and draw the "Percent Slope" group.  I'm not really interested in answering questions about why I would want to do this way, because it is kind of nutty, but rather, how to do this in the javascript code, so that I get better at tinkering with the widgets.  I'm able to write to the console if a user checks on "Critical Areas" but not at all sure how to have the code check on and draw the "Percent Slope" group:
From the "LayerListView.js" in the Layer list widger for webappbuilder:
   _onCkSelectNodeClick: function(layerInfo, ckSelect, evt) {
      if (ckSelect.checked) {
        layerInfo.setTopLayerVisible(true);
//  test how to find layer name
        if (layerInfo.title === 'Critical Areas')
              console.log(layerInfo.title);
//  I want this to check on and draw another group in the layer list--Any ideas?
      } else {
        layerInfo.setTopLayerVisible(false);
      evt.stopPropagation();
ikbelkachbouri
Thank you so much mehretab . And how to toggle between many maps ?
Mehretab
 my application also toggles between many services. If you see for example the 'Surfacewater bodies' group you got many services there (use the buttons on the bottom of the application to change between groups of maps). If you can give me the Ids for you services I can provide the complete code for you. Is you app publicly available?
ikbelkachbouri
I will publich for you the application and the list of feature services . thank you so much
http://41.231.36.249/sirgeo/rest/services/SIR_Gouv/D%C3%A9mographie/FeatureServer
ikbelkachbouri
This is a Demo .
Mehretab
Hi Ikbel,
Here is the code in your case. Justs copy and replace the _onCkSelectNodeClick function by this code.
Couldn't find a way to upload the file.
// id = "Démographie_2496" , title ="Population Totale"
//id = "Démographie_1127" , title ="Nombre de naissances"
//id = "Démographie_4091" , title ="Solde migratoire"
//id = "Démographie_2202" , title ="Nombre de mariages"
//id = "Démographie_4468" , title ="Nombre de divorces"
//id = "Démographie_7450" , title ="Nombre de décès"
//id = "Démographie_348" , title ="Taux Brut de Natalité"
//id = "Démographie_8957" , title ="Taux Global de Fécondité"
//id = "Démographie_1881" , title ="Indice Synthétique de Fécondité"
//id = "Démographie_5333" , title ="Taux d'Accoissement Naturel"
        if (layerInfo.title === 'Population Totale')  {
           //  how to find layer id
              //console.log(layerInfo.id);
this.layerListWidget.operLayerInfos.getLayerInfoById('Démographie_1127').setTopLayerVisible(false);
this.layerListWidget.operLayerInfos.getLayerInfoById('Démographie_4091').setTopLayerVisible(false);
this.layerListWidget.operLayerInfos.getLayerInfoById('Démographie_2202').setTopLayerVisible(false);
this.layerListWidget.operLayerInfos.getLayerInfoById('Démographie_4468').setTopLayerVisible(false);
this.layerListWidget.operLayerInfos.getLayerInfoById('Démographie_7450').setTopLayerVisible(false);
this.layerListWidget.operLayerInfos.getLayerInfoById('Démographie_348').setTopLayerVisible(false);
this.layerListWidget.operLayerInfos.getLayerInfoById('Démographie_8957').setTopLayerVisible(false);
this.layerListWidget.operLayerInfos.getLayerInfoById('Démographie_1881').setTopLayerVisible(false);
this.layerListWidget.operLayerInfos.getLayerInfoById('Démographie_5333').setTopLayerVisible(false);
   if (layerInfo.title === 'Nombre de naissances')   {
this.layerListWidget.operLayerInfos.getLayerInfoById('Démographie_2496').setTopLayerVisible(false);
if (layerInfo.title === 'Solde migratoire')  {
if (layerInfo.title === 'Nombre de mariages')  {
if (layerInfo.title === 'Nombre de divorces')  {
if (layerInfo.title === 'Nombre de décès')  {
if (layerInfo.title === 'Taux Brut de Natalité')  {
if (layerInfo.title === 'Taux Global de Fécondité')  {
if (layerInfo.title === 'Indice Synthétique de Fécondité')  {
           if (layerInfo.title === "Taux d'Accoissement Naturel")  {
      } else {
Make sure I didn't mess with the Ids
ikbelkachbouri
Thank you so much Mehretab . It ok for layer lists and how to toggle now between maps ?
RobertScheitlin__GISP
Ikbel,
   Are you asking to toggle between web maps (i.e. the whole map that the app uses and not just a layer in the map)?
ikbelkachbouri
Hi Robert ,
yeah i mean the hole map that the app uses like in Mr  Mehretab T.Sium Demo : ArcGIS Web Application
I'm using  WAB for arcgis 2.7 . Thank you so much Robert .
Ok, I am not sure he is actually switching the web map but let wait for him to reply.
