Web Appbuilder popup nls
6010
06-15-2016 03:44 AM
AveKargaja
Recently, I have been messing around with customizing a little bit my web apps and now I am in the point where I would like to know where the nls library files are located, where I can change the values of "Attachments:", "No attachments found" etc fields of popups.
RobertScheitlin__GISP
Ramon,
  I guess the best place would be the MapManager.js as you are dealing with the popup.
Ramon,
  For that you will have to include the 'dojo/i18n!esri/nls/jsapi' : esriBundle require and define your desired text for the
esriBundle.widgets.popup.NLS_attach and esriBundle.widgets.popup.NLS_noAttach
AveKargaja
Thanks, but Robert, could you be a bit more specific, like into which file should I add this i18n require when I'm using WAB developer edition based apps. There is just too much code for a  novice code explorer
Ramon,
AveKargaja
Robert, you are right, the place to set the text strings (in case they are not included in the app nls libraries) is from MapManager.js, but as my chrome browsers console is not working as expected then can you tell me if I can find somewhere the full list of esribundle.widgets text strings. I am most interested of those which are here on the picture.
Ramon,
Here are the esri ones;
esriBundle.widgets.popup.NLS_zoomTo
esriBundle.toolbars.draw.addPoint
The file chooser is a dojo one you will have to Google that.
